    Jul 2012
    Baltimore, Maryland
    439
    Receiver/ servo problems
    Alright here's a good on for you guys. Can you fry or lose a channel on a receiver. I had my servo in n it was working fine. I did some slow crawling over my 3.3's tire n left it in that position for a while n forgot to turn it off. When I came back I had no steering input. Oh great fried brand new 5085. Nope took it to lhs they put it in a slash it worked fine I came home put in merv n nothing. Put in my 3.3 n worked fine. Put back in merv n nothIng. Changed controllers, still nothing. Mean while the motor works fine and the receiver is lit green. ??????***. The receiver has other channels, can I make one of these my steering? Thanks for the help guys.
    BB MERV/T8 Rusty/OS21REVO
    Drive it like its Hot
    Alma, Michigan
    12,290
    Both channel 1 slots are burned out?
    You can make another channel be controlled with the steering wheel...
    but it will take some pretty decent soldering skills.
    Jul 2012
    Baltimore, Maryland
    439
    I have the skill but will have to get a diff iron. Can you give a little explanation. I'll open it up after dinner. This is my second rec. thanks Jimmie. Oh n I'm using a three channel tqi, if that matters its from my 3.3 revo
    Alma, Michigan
    12,290
    You would basically be wiring channel 3 to the steering wheel... but this will also mean that channel 3 for your 3.3 would be operated with the steering wheel.
    It might be time to use Traxxas' lifetime replacement program...
    Jul 2012
    Baltimore, Maryland
    439
    With what it's worth in down time I guess I'll be hitting up the lhs. Thanx Jimmie. I need three to be reverse for 3.3.
    Alma, Michigan
    12,290
    Kinda figured.
    See if the LHS will do a swap??
