Results 1 to 16 of 16
    330
    Pinion gears for MMM 5mm shaft.....Who makes them????
    Hello everyone i am struggling to find the 19t and 21t pinion gears that fit the CC MMM 5mm shaft. Other than RRP do you know anyone else who makes them?
    Thank you.
    SUPERMAXX, ERBE, T-MAXX, MERV
    SAVAGE &TROPHY FLUX
    May 2009
    Edmonton, Alberta
    3,604
    Plenty, what pitch are you after? Novak, Castle, RRP, Ofna, Tekno...
    5mm 19t - MOD1
    http://www.amainhobbies.com/advanced...mm+19t&x=0&y=0
    5mm 19/21t Mod.8 seems to be quite a bit limited, which might have lead to your question.
    I would consider changing up to Mod1 if you have the chance.
    Central, WI.
    235
    rcmonster.com has them. Go to Rc monster Parts then go to page 5. They have all pinion sizes.
    Apr 2009
    380
    I personally am very happy with my RRP gears. They are my go to manufacture.
    kansas
    7,895
    330
    RC monster it is then, I will be buying some 8mm drive cups to fit on the LST diffs therefore that fits me perfectly.
    SAVAGE &TROPHY FLUX
    330
    What is the difference between MOD 1 and MOD 8......can i use both my MMM ???
    SAVAGE &TROPHY FLUX
    Long Beach, California
    6,727
    mod1 have bigger tooth gap and you have to mate it with the same pitch spur. i run mod 1 with mine i find it easy to mesh, not that i have problem meshing the 32 pitch lol.
    330
    so mod8 is 32 pitch and mod1 is 31.75?
    so where do i find 31.75 pitch spur gears for the erbe??
    SAVAGE &TROPHY FLUX
    6,727
    correct........
    330
    is there any particular reason why they have used 31.75 pitch?
    SAVAGE &TROPHY FLUX
    15,900
    Mod 0.8 is 31.75 pitch which is why it is interchangeable with 32P.
    Mod 1.0 = 25.4P (25.4/25.4=1.0)
    Mod 0.8 = 31.75P (31.75/25.4=0.8)
    I have found the 32P, 5mm bore RRP Xtra Hard pinions to be excellent.
    Alt-248 on the number pad =
    330
    Now i am confused..... so mod0.8 is 31.75 pitch and mod1 is 25.4pitch? then where is the 32P and what is 25.4 with which you divide the other values??????
    Can i use a mod0.8 (31.75P) pinion gear with a 32pitch spur gear?
    SAVAGE &TROPHY FLUX
    6,727
    32 pitch and mod.08 are so close that they mesh perfectly to eash other. so yes you can use mod.08 or 32 pitch either way you pick they work fine.
    330
    thanks a lot thats great to hear
    SAVAGE &TROPHY FLUX
    3,259
    I have a robinson racing 19 pinion...its holding up well; they are pricey thou .
    Rock n Rolla !
