Results 1 to 15 of 15
Thread: Help!!!!!
    Help!!!!!
    So i just got my new revo i had it running to break it in and when i turned it off and went to turn it on my light on the optidrive is solid red as well as on the receiver the light is solid red .My transmitter light is green i have no controls i cant get the remote to move any of the servos what is going on ? any help is much appreciated as it is very frustrating thank you guys for you help in advance
    Kauttua city, Finland
    197
    I don't remember the exact meaning of the light colors and flashings but i guess that your battery is almost empty? If you have the manual, you can check it from there, or you can read the manual also here on Traxxas sites.
    |Traxxas|Revo|3.3|#5309|FIN|
    191
    If the receiver battery is low then the fail safe may have kicked in. The standard receiver battery doesn't have a very high mAH rating, only 1100mAH so doesn't last to long. I find mine lasts just over 4 tanks of fuel, this would also depend on how much steering & throttle/brake on/off is used, the more you use the faster the battery will go flat.
    Jun 2011
    Lucas, Ohio
    722
    Sounds like someone needs to upgrade to a hump pack lol.
    191
    Quote Originally Posted by 2010450x View Post
    I know I will be soon when I find a suitable pack with a high enough mAH rating.
    Do you have any suggestions that will suit the Revo & fit without any problems.
    Nov 2003
    Long Island, NY
    2,602
    You wouldn't use a hump pack in the Revo. The Revo battery box is designed for a flat pack. Doesn't the Revo come with the 1200 mAh 5 cell flat pack? That's what I use in mine and I get 2-3 hours of run time on it.
    Rustler-3.3,Revo-Hyper .21,Jato-3.3
    lots of mods
    Jun 2011
    Lucas, Ohio
    722
    Ahh, I'm a T-maxx convert lol so I apologize for that part lol. Maybe the factory flat pack is defective?
    Nov 2003
    Long Island, NY
    2,602
    That's possible. I don't have the optifdrive on mine and I have a single steering servo which help increase the run time but 40 minutes to 3 hours is a big difference. The Traxxas flat pack in my Jato and the hump pack in my Rustler also last 2-3 hours.
    lots of mods
    197
    Dynamite has 1700mAh flat pack.
    191
    Yeah a flat pack is what I'm after, pretty sure the standard pack in mine is 1100mAH, I doubt that it would be defective though as my brothers is exactly the same, both purchased from same shop at the same time. I was hoping I could find something at least 2000mAH so it will last a fair while. Might even look into getting a couple of rx packs made up to suit if I can't find any with a high mAH rating.
    9,703
    I know with my Revo I can fit both a flat pack and a hump pack (which I have now). But it is a 5308 Revo with the compact electronics boxes which are oft referred to as the Slayer-style boxes.
    If you are still using the wall charger that came with the Revo, it may be in your best interest to get a decent, yet inexpensive battery charger that will do receiver batteries too. I have a 1/16 vehicle that I use lipos for so I bought a Thunder AC6 that can charge those and the receiver pack.
    191
    Will the better charger give the battery a better charge and make it last longer? I might have to have a look & see whats around in Australia or maybe check out ebay & see what is available to suit both the rx & the starter wand batteries.
    9,703
    It'll charge it quicker.
    Nov 2003
    Long Island, NY
    2,602
    I have the Traxxas 3030X peak charger and I find it gets a lot of false peaks. When the light goes green, I unplug it and plug it back in and it will charge some more. I do this 3 or 4 times or until the light goes green in under a few minutes.
    lots of mods
    191
    I do that with the battery charger for the AA batteries in the control, when it shows their charged I turn off charger for a minute then turn it on again, normally 2 times does the trick. Tried it with the standard rx pack charger but the light just goes green again so won't give any more charge.
