Results 1 to 3 of 3
    13
    Tips on removing / fitting knuckles to half shafts
    Folks,
    I'm wanting to swap out my half shafts as part of an e-slayer project and I made a complete dogs dinner of the first one. Anyone got any tips on how to do this easily?
    665
    You have the stub axles and bit that connect to the diff or trying to get the whole thing in?
    If your trying to put the stub axles and other bit on, you just pop off one of the e clips on the joint, it'll fall into 3 pieces, after that just rebuild the joint between the shaft and other bit.
    If your trying to get the whole thing in, your gonna have to at least loosen the knuckle a lot or take it off, put the stub axle through it then bolt the knuckle back up.
    Sent from my Transformer using Tapatalk 2
    13
    Thanks. I'll give it a go.
