Hello - I'm trying to calibrate a TQ 2.4 radio (not TQi) to my SCT, when i plug it in and bind it to the receiver I am able to successfully calibrate the throttle channel but steering will not work at all. I've tested other brands of Tx/Rx on the car and the steering works fine. It's as if D/R is dialed all the way down where the wheels will flick slightly left or right. I've tried resetting the Tx completely but that didn't seem to do anything, I tried setting the multi-function to steering rate and dialing that up, reset Ch. 1 in the menu tree, reset steering EPAs in the menu tree and nothing seems to help. Was just wondering if there's anything else I should try or if this sounds like a defective product issue?
Thanks.
