Results 1 to 27 of 27
    Oct 2011
    75
    Somthing happend to my car - need help
    Hi everyone
    So after my first run with the MMP 2400 combo i have to say it was a blast! Wheels on demand and the car flying.
    But now after charging the battery and took the car for another spin, something happened.
    When i hit the throttle the front wheels spin first very fast and after a second the rear wheels start to spin to.
    The battery is fully charged and the slipper cluch is 1/4 turn.
    Whatdo you think is the problem?
    delaware
    937
    loose wheel or pin is broke in the rear wheels , possibly a spun hex
    Jul 2012
    246
    If u dont have stronger axles a driveshaft in the rear is broke probably broke
    sl2sh, p4de trail truck
    Oct 2011
    75
    I have MIP front and rear and a revo slipper also.
    Jul 2012
    246
    Then look at ur rear wheel hexes chances are one is stripped
    Oct 2011
    75
    I will look on them.
    The problem is defiantly in the rear right?
    Jul 2012
    246
    If when u apply power the front wheels turn and the rear don't then it is in the rear
    Oct 2011
    75
    When i hold the car in the air and hit the throttle it seems that all 4 wheels spins in the same time, but when i put the car on
    the ground and hit the throttle it happens.
    Jul 2012
    246
    Stripped hex is most likely your culprit are u using aluminum hexes
    Oct 2011
    75
    Quote Originally Posted by RCTRAIN View Post
    No, i will check now the hexes
    Wales in the UK
    5,446
    Your rear hexes have gone to rc heaven...peace
    RC Turnbuckle Jr. vxlrocket's Avatar
    Dec 2007
    Manassas, Va
    6,654
    a couple of other things to check as well.....
    make sure you didn't lose a grub screw in one of your rear diff output yokes....that happens to me sometimes and will mimic the hex issue
    also make sure the spline that the center drive shaft goes into is tight on your slipper or center diff (which ever you run)
    Associated rc8TE, rc8.2E, B4.2, Ofna LX2E, Slash
    Oct 2011
    75
    It cant be the rear hexes if i have MIP's no?
    May 2005
    Minnesota
    988
    Could be hexs, they sometimes round in the wheel. Easy to check.
    2x Stampede VXL
    Stampede 4x4
    Wales in the UK
    5,446
    Quote Originally Posted by No One View Post
    +1 on tht i have mips and have rounded out wheels a few times...hope you get up and running soon bro..peace
    Oct 2011
    75
    I think that you right guys, took off the wheels and in the right one the wheel hub was stuck in the wheel so maybe that's was the problem.
    You can see in the picture the stuck wheel hub.
    Wales in the UK
    5,446
    Yes that has happened to me a few times but i have now glued my traxxas alu hexes in my wheels with loctite power flex and so far so good and that is running a tenshock sc411 3500kv on 2s and 3s i have the old pinned mips just so you know.....peace
    Oct 2011
    75
    So i have to glue the wheel hubs to the wheels?
    Wales in the UK
    5,446
    Glue the hexes into the wheels and let them set for 12 to 24 hours before you run your truck
    Oct 2011
    75
    The hexes you mean is that what stuck in the wheel in the picture?
    Wales in the UK
    5,446
    Yes dude they clip over the pins
    Oct 2011
    75
    Thanks man!
    Wales in the UK
    5,446
    Quote Originally Posted by vatomer View Post
    Thanks man!
    No worries dude hope you get back bashing soon...peace
    Oct 2011
    75
    I use the stock Hex and i didn't know that theirs a MIP Hex.
    this is what i need :
    http://miponline.com/store/product438.html ?
    Wales in the UK
    5,446
    I have the old pinned mips so i use traxxas alu hexes part no. 1654x
    McHenry, Illinois
    648
    Smile
    Not really... if you broke the pin that the hex snaps on to then the lock screw alternative might help but it seems like your problem is the same as I once had...too much torque for those little hex wheels. I bought the AKA 17mm adapters and a set of RPM 17mm "stablemaxx" wheels. you can mount most bigger 2.8 tires to them like the trenchers or the mashers or even go for some e-savage type baja tires! You'll never strip another wheel. I had just 2 runs on a new pair of trenchers and they ended up smoked because of the MMP 2400 SCT...never again!
    When Boy When, Are You Gonna Get Your Act Together
    Oct 2011
    75
    Thank you all for your help
