Results 1 to 7 of 7
    Jan 2004
    New London, NC
    115
    Wheel/Tire question
    I picked up a set of used wheels and tires off a brushless 3908. Was planning to put them on my 3903 but when I tried to put them on the wheel nuts go straight thru the opening in the wheel. What do I need to have to make these fit? I tried searching with no luck.
    55
    I'm pretty sure the 3908 model uses 17mm hex for it's wheels/hubs, and the stock 3903 uses 14mm hexes, so you'd need a 17mm adapter.
    Jan 2004
    New London, NC
    115
    Thanks! I appreciate the help
    1,350
    Yep, Rocklobst3r is correct. Just be aware that the Traxxas 17mm adapters have a lot of play in them. I'm actually using a cross Traxxas/HPI hex and nut that works well. There are some other good adapters that folks are using. I just can't think of the names right now.
    Sep 2010
    Chicago, IL
    2,016
    MAximizer makes really tight nylon hexes. Thats what I use. and theyre only $4 instead of $25.
    Doublethink: 2+2=4 while 2+2=0
    Jan 2004
    New London, NC
    115
    I'll have to check those out!
    Sep 2010
    Chicago, IL
    2,016
    They also grip the wheel so if a nut comes off, you have time to stop before the wheel goes flying (ive done that to many times).
