Results 1 to 7 of 7
    Jan 2004
    New London, NC
    115
    Wheel/Tire question
    I picked up a set of used wheels and tires off a brushless 3908. Was planning to put them on my 3903 but when I tried to put them on the wheel nuts go straight thru the opening in the wheel. What do I need to have to make these fit? I tried searching with no luck.
    55
    I'm pretty sure the 3908 model uses 17mm hex for it's wheels/hubs, and the stock 3903 uses 14mm hexes, so you'd need a 17mm adapter.
    Jan 2004
    New London, NC
    115
    Thanks! I appreciate the help
    1,349
    Yep, Rocklobst3r is correct. Just be aware that the Traxxas 17mm adapters have a lot of play in them. I'm actually using a cross Traxxas/HPI hex and nut that works well. There are some other good adapters that folks are using. I just can't think of the names right now.
    Sep 2010
    Chicago, IL
    1,753
    MAximizer makes really tight nylon hexes. Thats what I use. and theyre only $4 instead of $25.
    "American Muscle beats import any day of the week"
    Jan 2004
    New London, NC
    115
    I'll have to check those out!
    Sep 2010
    Chicago, IL
    1,753
    They also grip the wheel so if a nut comes off, you have time to stop before the wheel goes flying (ive done that to many times).
