do i have to have a lipo balencer to charge a lipo
it is best to balance charge .if one cell is higher than the other(s) it can over charge . if it's a newer pack you might be ok . if you have a voltmeter and some pins you can check the voltage through the balance plug to see if they are close
Balancing also helps increase the life of the lipo and run quality on the car.
rustler vxl " Stealth from below"
Traxxas recommends always balancing their LiPos. Support of other LiPos is not permitted on the Traxxas forum.
