Results 1 to 22 of 22
Thread: ERBE LiPos
    144
    ERBE LiPos
    So I think my current Lipos are on their way out and im looking at purchasing some new pairs within a reasonable cost.
    Im looking at a 3s and 2s setup
    - 3s 11.1v 5000mah 20c (maybe higher mah rating and C ratings)
    - 2s 7.4v 5000mah 20c (maybe higher mah rating and C ratings)
    SPC are currently off my list as their shipping costs were overpriced to Australia
    Will consider SPCs if there are other places to purchase them
    Thanks.
    Long Beach, California
    6,203
    check out this site, gens ace are great lipos for a cheap price. http://www.hobbypartz.com/batteries.html
    not sure if they ship outside USA.
    | Rally GT8 Powered By CC |
    51
    Go to ebay and get some from China. Only a few companies actually manu lipo batteries anyway and they will be the same. Winforce, or winmax or something like that.
    144
    I was looking at and considering those batteries
    Ended up being $150 plus $50 shipping
    144
    Quote Originally Posted by LuvMyBasher View Post
    How are they in the long run though?
    Virginia
    826
    I'm not sure if you can be very picky from Australia.
    You can have a cheap battery and high shipping, or you can pay more locally. I'm not sure if there is another option.
    ERBE, Summit, Thunder Tiger MT4
    kansas
    7,820
    If you can I would really look at a 5000 mAh 30 or 40C.........150 amps & 200 amps
    a 5000 mAh 20c is only 100 amps........
    This is a good start..
    Just don't buy no name Ebay batts...
    MY BATTS:
    2S 9000 x 28C = 252,000 divide 1000 = 252 amps
    2S 8000 x 28C = 224,000 divide 1000 = 224 amps
    3S 5200 x 40C = 208,000 divide 1000 = 208 amps
    2S 4700 x 25C = 117,500 divide 1000 = 117.5 amps
    ^I run in my Summit.. ^ Requires proper gearing^
    ( mah x c rating / 1000 = amps)
    The
    more amps the better / minimun of 120 amps.
    The ESC will only draw the amount of amps it needs.
    Higher the mAh the longer the runtime.
    For brushless systems 8000 mAh about 45 min & a 5000 mAh about 30 min.
    Times are longer for brushed systems.
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    A temp gun is kind of a must have.....
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    Besure to check sizing before you buy any batteries...
    In time some batteries will become discontinued...
    No particular order as to good, better, or best....
    2S
    With larger Lipo battery wires, you might need to - enlarge the exit hole on battery doors....
    or run wires out the vents..
    Direct Fit...........
    2s GensAce 5000 mAh 40c
    2s Gensace 5300mah 30c softcase packs
    2s HiCountryHobbies/Billowy Power 5200 mAh 50c
    2s Hyperion 5000 mAh 45C Soft
    2s RC DUDE Power 5000 mah 35c
    2S Sky Lipo 5000 mah 40C -- fit snugly
    2s SPC 5000 mah 25C hard case
    2s SPC 5200 mAh 40C
    2s SPC 5400 mAh 50C hard case
    2s SPC 6000 mAh 30C hard case
    2s SPC 8200 mAh 30c
    2s SMC 5400 mAh 50c
    2s SMC 6000 mAh 28c
    2s SMC 8000 mAh 28C Soft Case Lipo
    2s SMC 9000 mAh 28C Soft Case Lipo
    2s SMC 9200 mAh 50C
    2s Team Orion carbon 7000 35c
    2s Thunder Power 45-90c 5000mah
    2s Traxxas 5800 mAh 25c
    2s Traxxas 7600 mAh 25c
    Mod's.............remove retainers & back out or trim screws if they extend into battery compartment
    2s SPC 8200mAh/40C
    3S
    Direct Fit..............
    3s Hyperion 5000 mAh 45C Soft
    3s Max Amps -6000xls
    3s Team Orion Carbon 4700 mAh 45C
    3s Kypom K6 6000 mAh
    3s RC DUDE Power 5000 mAh 35c snug 29mm tall
    3s HiCountryHobbies Billowy Power 5200 mAh 50c snug 28mm tall
    Mod's..............remove retainers & back out or trim screws if they extend into battery compartment
    3s SMC 5600 mAh 50C
    3s SMC 5500 mAh 28c
    3S SPC 5200 mAh 40C soft case
    3s SPC 5400 mAh 50C soft-case
    3s Thunder Power 3s 45-90c 5000mah
    3s Traxxas 5000 mAh 25c
    Traxxas link to batteries
    http://traxxas.com/products/parts/ac...s-applications
    http://traxxas.com/products/models/e...less-batteries
    battery compartment:
    list needs udated any new batts let me know........
    144
    Thanks 87
    Please watch for filtered words, denoted by *s, in your posts.
    -ksb51rl
    Athens, Greece
    571
    hey man.
    im my small 2 years experience on helis and e-revo, i would never buy any battery under 40-45C anymore. nobody out there has true C ratings anyway, there is a forum somewhere explaining that and testing batteries internal resistence etc. but i always find the 40+C more powerful and lasting on any type of rc
    those 40c gens ace seem nice
    144
    Quote Originally Posted by fuzion View Post
    hey man.
    Thanks for that, Ill look into 40-45C LiPos now
    144
    Would these be good for the E-Revo?
    http://www.hobbypartz.com/98p-60c-5000-3s1p-3333.html
    Although their about 2mm taller for the battery compartment
    15,441
    Total falsehood.
    Quote Originally Posted by phsycophantsy View Post
    No they won't. 31mm is the absolute maximum.
    Alt-248 on the number pad = į
    Pa
    566
    SPC racing has good lipo's. 3s 5400 mah that fit perfectly in the Erbe.
    http://www.spcracing.com/index.php?productID=121
    144
    Quote Originally Posted by guardog View Post
    SPCs shipping rates are too high for me
    447
    from that very same page...it says it doesn't fit erbe...
    PACK DIMENSIONS: 136mm long x 43.5mm wide x 34mm deep, 390g. Weight includes Traxxas or Deans connector. This pack does NOT fit the Traxxas ERevo, but by using the Traxxas Battery Expansion Kit the pack will fit the Traxxas Slash 2WD and 4WD, Traxxas Stampede 2WD and 4WD and Traxxas Rustler and Bandit. (Please check your vehicle for size and fit) This pack will fit in most 1/10th scale, ground-based vehicles; however chassis modifications may be required for others.
    so i'm wondering what they mean when they say deep and wide?
    3,255
    Quote Originally Posted by IvVaum View Post
    Here you go mate, battery tray dimensions
    Rock n Rolla !
    Dec 2004
    3,643
    .... shipping rates are too high for me
    The US Postal system added a new regulation this past May that prohibits shipping LiPo battery packs using USPS as a courier. This regulation change forced many companies to go the UPS route; however UPS international shipping costs can be and many times are extremely expensive. Typically these high shipping costs are just passed on to the customer as the battery companies have no control over these costs.
    Feb 2008
    Fl
    3,062
    I think you are going to be stuck with outrageous shipping no matter who you get them from, unless you can find a supplier locally. Have you considered making some packs out of A123 cells, maybe you could find them cheaper than rc car packs.
    144
    Quote Originally Posted by rjm2519 View Post
    Around $50 I am fine with, just SPC is charging $150.
    No I haven't, I think if i tried that, it would blow up on me
    Dec 2004
    3,643
    Around $50 I am fine with, .... is charging $150.
    Again, it is really UPS charging that amount.
    Pa
    566
    The owner / sales rep informed me personally that they WILL fit. Don't personally know as I do not own any yet
    kansas
    7,820
    Jakey is the owner
    they will fit with mods
