    7
    Traxxas remote 6509 channel 2 with EZRUN 60amp ESC
    I am bagging my head on this one.
    Short story--I have a eStampede and have upgraded to brushless. HobbyWing EZRUN 60 amp ESC with a Tacon brushless motor. I have been using the 27Mhz radio without a problem. Figured I would upgrade so I got a traxxas 6509 2c hannel radio with 5 channel receiver.
    Syncing the TX and RX was fine. Steering servo works with no issue. The problem that I am having is programming the throttle. Channel 2 will not program. I have reset the remote to default for electric cars, i have tried reversing the throttle and nothing is happening.
    To get fresh eyes on it i took it to LHS with manuals and they could not get it to work either.
    Anyone have any ideas on how to get this to work? Any help would be appreciated.
    12,290
    What, exactly, is it doing?
    Dec 2006
    4,398
    Have you tried to install the servo on channel 2 and see if it works?
    Also, you need to re-program the ESC.
    7
    The issue is that the ESC will not program throttle on channel 2 of the receiver.
    I just tried swapping the connections. The ESC does work and the motor turns when plugged into channel 1. The steering servo does not work on channel 2. If i move the throttle back and forth I would expect the steering to move.
    12,290
    Sounds like a bum Rx...
    Try giving Traxxas a call... they may warranty it for you.
    7
    Thank you for the info. Ill try a new RX and see what happens.
