Hello all...
I am newish to this and having problems lining up the wheels, truck always wants to pull to the left.
I have tried adjusting turnbuckles and they all look even, what else should i try?
Thanks.
SC
Hello all...
Thanks.
SC
If it only slightly pulls to the left, use the steering trim knob on the transmitter to get it going straight.
take a look at wheel bearings and possibly diff bearings also... make sure your suspension is smooth and not binding
Thanks for the input, the bearings are fine.
As mentioned, it's only pulls a little, it's fine with the trim adjusted.
Thanks.
glad you got it sorted out... only reason i mentioned it was that the other solution was already mentioned... there is no such thing as to much knowledge... have fun...
