Thread: Center Diff
    Gulfport, MS
    319
    Center Diff
    My Slayer Pro tends to seem more rear wheel drive than four wheel drive. Does it have a open center diff stock? Would the center diff with a thick oil fix that?
    9,769
    Just a straight shaft with a gear on it, no diff in the transmission unless it was installed there.
    Grafenwoehr Germany
    1,304
    Yes it should be the same center diff kit for the revo also pick up some 500k oil to put in it that will help
    Gulfport, MS
    319
    If it has a straight shaft with a gear shouldn't that be even power to both front and rear?
    9,769
    The final drive gear is different between the Revo and Slayer so it will be a different kit. And yes, if it has the original forward-only conversion then power goes to the front and back equally. It could be there is a stripped hex up front so the power is unloading there. Or naturally the truck squats under power and the rear tires have more traction.
    Gulfport, MS
    319
    The truck has only 1 1/2 quarts of fuel through is so I'm assuming its just the truck squats
    Riverton Utah
    4,363
    Yep. Sounds just like mine.
    Sep 2011
    Tucson, AZ
    69
    Quote Originally Posted by Emaxx1991 View Post
    I just got my center diff and rear brake kit the other day. I have read in several posts to run 500K oil in the diff. What benefit with that give over the 100K oil that the diff shipped with?
    I usuall run the truck on loose dirt, so would the masses still recommend switching to 500K oil?
    V/R
    Bill
    Grafenwoehr Germany
    1,304
    Yes 500k is still a little to thin IMO but that's what I use
