Results 1 to 23 of 23
Thread: MMP question
    246
    MMP question
    what all do i need to get if im getting a mmp and a novak motor (bec, glitch buster, fan, ect...)
    which would you recomend the castle feild programer or the the castle link
    i will be using the stock servo and a spektrum sr300 receiver
    sl2sh, p4de trail truck
    South of St Louis
    6,053
    I prefer the castle link because:
    1. I usually make one setting and leave it.
    2. I usually bash on the street by my house so I don't need to make changes at the track.
    Guys who run at the track or make frequent changes usually prefer the field card.
    Do buy the castle link extension so you don't have to open the receiver box to access your MMP.
    Jun 2010
    Miami, Fl
    6,731
    MMP comes with a fan so you don't need one, field car or usb adapter is a must, it works good with stock servo, and spektrum rx, if you plan to run stock motor only need to solder 4mm bullet connectors to the motor.
    Dec 2007
    Manassas, Va
    6,735
    Quote Originally Posted by RCTRAIN View Post
    1. castle creations BEC...i gave you a bunch of links in the other thread you posted in. even a you tube video on how to hook it up.
    2. castle link...this way you can program the BEC too.
    3. you can run a fan, but i much prefer a good heatsink and proper venitilation holes in the body.
    (2)RC8TEs, RC8.2E (2)slash 4x4 2650 pede 3800
    246
    do i need a bec or glitch buster
    i wil run a novak 5.5 motor
    Dec 2007
    Manassas, Va
    6,735
    u CAN run a glitchbuster, but it still might glitch dependingon what novak motor you get. the BEC is 100% effective.
    246
    ill be running the novak 5.5 550 sensored bl motor
    246
    Quote Originally Posted by RC-Fan View Post
    is the fan wired into the esc or do i need to use a receiver channel
    Dec 2007
    Manassas, Va
    6,735
    you'll need a bec...to answer the question you had in the other thread....the aux is the same as the battery. but you need to choose. either the fan or the lights....or you need a receiver with more channels. or you can run your fan off of a mini lipo pack. i did that for over a year. they weigh less than an ounce and will be more effective imo
    Dec 2007
    Manassas, Va
    6,735
    the esc fan is wired into the esc...you'll need to either find a port for the motor fan or provide another power source.
    246
    what kind of gearing would you recomend for a 5.5 550 novak hv motor
    i have trenchers and dont want to go fast i want to crawl as best as a pede can
    Dec 2007
    Manassas, Va
    6,735
    if you want to run the motor fan off of a lipo, i used one almost identical to this one for a year: http://www.hobbypartz.com/32p-850mah-2s1p-74-20c.html
    246
    so i need a bec, castle link and i was thinking a 12t pinion what do you guys think
    Dec 2007
    Manassas, Va
    6,735
    what spur are you gonna run?
    246
    i plan to run the 54t
    Dec 2007
    Manassas, Va
    6,735
    that should work quite well. that was the same gearing i used at my track when i ran the 5.5. i never had any heat issues...if your racing...you'll never need any more than a 2S. it's crazy fast on 2s with the 5.5
    246
    thanks for your help
    so il get the castle bec, castle link and a 12t pinion
    Dec 2007
    Manassas, Va
    6,735
    glad to help
    246
    Quick question what does a bec do
    Dec 2007
    Manassas, Va
    6,735
    246
    so if i run only 2s and stock servo do i need one or can the esc power the receiver and servo
    Dec 2007
    Manassas, Va
    6,735
    yeah, you'll still need the BEC. i've never not needed one when i've used a novak 550. it doesn't matter if ou're running 2 or 3S
    246
    ok i guess ill just get it
    thanks again for your help
