Results 1 to 10 of 10
    Planet Vegeta
    651
    Question is my tranny hurt by this
    i cleaned out my tranny's grease and i put motor oil in it, will the teeth wear out
    Brooklyn Park, MN
    959
    Shouldn't hurt, but it probably won't do any good. The oil will just run out. Use some good grease.
    Samsung Epic - Tapatalk 2
    greenwood cemetery bashplex 8))
    12,349
    Motor oil? May affect the plastic part of the diff housing.
    Whats in my wallet?
    I cant afford a wallet...
    Planet Vegeta
    651
    i only got the grease off the teeth and the plastic cover
    far NE PA, near binghamton
    57
    have u ran it yet? the oil will find its way out of the tranny, probably make a mess, and when its all gone then theres no lubricant,that can cause a issue. I have used heavy bearing grease with no problems ran on 3s.
    Planet Vegeta
    651
    i put all pursose grade 2 grease and wd-40 to slightly loosen it
    Knoxville, TN
    592
    Plain wheel bearing grease is easy cheap and probably the best solution. Just stick a little in there and let the motor put it where it needs to go. You wont have to look at it again until something breaks.
    South of St Louis
    5,793
    Quote Originally Posted by f687s View Post
    Motor oil and grease are petroleum based so the oil shouldn't hurt it more than grease.
    Brooklyn Park, MN
    959
    I use Mobil 1 grease in my tranny.
    Planet Vegeta
    651
    i used 10wd-30 and the comp is a v with one side red and the other blue
