    Sep 2012
    227
    clicking steering servo.
    so this is the 6th time I've driven my Summit and the steering servo is week and I think it is striped. When turning to the right it doesn't have the power to turn all the way. If I lift the front wheels of the ground it will turn fine. I'm not positive which servo it is tho. Could it be something other than what I think it is? It will turn fine in the other direction tho...... I really don't know what it is ..
    Iowa/ill/KS
    351
    Disconnect the servo arms and manually check steering to make sure nothing is binding although its pretty much always the servos. Pretty easy to burn one up and have the opposite one strip out trying to steer while fighting a dead motor. Good start though to make sure everything is moving properly.
    Sep 2009
    Victoria B.C Canada
    5,166
    My guess would be one servo has some teeth missing.unhook one servo horn at a time.
    lift front of truck,better yet put it on a stand or a gallon paint can whatever you store it on.you should store it with the suspension unloaded.
    turn slowly while giving slight resistance with your hand.
    If turns smooth check the other one the same way.
    If there are teeth missing you should be able to tell by the feel of it.it will stutter a bit or stop "pushing" against your hand
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Sep 2012
    227
    thanks guys I'll check and see. If I do need to replace one is there a better one you'd recomend that will last longer? I beleve in upgrading when it is time to replace, if you get my drift.
    Sep 2009
    Victoria B.C Canada
    5,166
    There are a few threads here on that very subject.I am running a single hitec
    If you do upgrade a aluminium servo horn is also a good idea.Bellcrank some run aluminium some don't.I do
    Steering is very good now.
    they have tried
    Jul 2012
    50
    Mine was doing this also. I was able to open the servo up and repair it. I had chipped a tooth off. I think there was a tab I had to cut off the gear so I could spin it 180 around to use the other side. I think the tab was just a dead stop. If you find out it is the servo don't be afraid to try and fix it. Cause if you can't or make it worse, you all ready needed a new one.
    Sep 2012
    227
    new hitec servo on it's way....
