Results 1 to 15 of 15
    Sep 2012
    225
    very bad tire wabble.....
    so my new tires wobble something awful! I thought I read that I could unglue them and reglue them but I'm not sure.
    Sep 2012
    AZ,tucson
    18
    Quote Originally Posted by 04zrx View Post
    Yes indeed you can..just boil them till the glue becomes goo and you can pull the tires off then u reglue them.... Blocks are wicked just unscrew em
    Jun 2009
    Indianapolis, IN (castleton area)
    423
    i would 1)search cuz this is unfortunately very common for the summit hexes (but also fixable!) and 2) try to determine if it is something to do with the actual tire or if it’s the hexes… I’d hate for you to glue and unglue when that’s not the root of the problem. ….i’d hate to think that if it is the hexes, they would be that bad on a new truck (call support?)…
    Alma, MI
    12,280
    Is it new?
    My Summit wobbled like crazy until I drove a few packs through it. I think the foams are not set properly... I believe they are just stuffed in there and glued up; driving it helps seat them in place.
    Toronto
    2,326
    Yeah driving certainly helps break in the new tires! They wobbled HORRIBLY I was so upset, but after about 45 minutes of driving, turning, crawling, going fast... they were great! The HEX wobble is noticeably when the car is stationary, just... try to rock the wheels, if they move easily find out where their weak point is and go from there! =)
    Sep 2012
    225
    what are the "hexes" the lugnuts? I'll drive it a bit more and see if it improves, the Summit is new.
    Alma, MI
    12,280
    For some reason, I could only find green ones at BuyTraxxas...
    15,559
    The hex wobble is due to wear. It will not have occurred yet.
    Squished foams is the most likely culprit in your case. This is mostly due to the way the Summit is boxed.
    Alt-248 on the number pad =
    HESPERIA, SoCAL
    248
    It's also a good practice to keep the vehicle off the wheels when not driving it. Keeps flat spots to a minimum.
    RC Stand build thread here.
    X1^
    Jul 2012
    the middle of nowhere
    419
    If the wobble is due to a flat spot in your foams, once you get it worked out you can set your Summit on a coffee can until you get a dedicated stand made (if you do desire)
    Sent from my iPhone using autocorrect
    Jun 2009
    423
    not sure id agree... i have brand new (red) hexes and i have one wheels that wobbles like crazy and other thats 'normal' lol
    Arkansas
    522
    +1 on keeping the truck suspended while not being used. I realize it's new but you have to remember in was stored in a box and warehouse before you got it.
    Drive it to work out any of the foam issues and store in so the tires are not touching. I took an old 4x4 and cut it about 12” long and then screwed a piece of 2x6 about 6” going the other direction …..to give it more height and to widen the base and make it more stable. You can also buy stands or make them from PVC of anything you have handy. Just let the suspension hang.
    Just my 2 cents.
    SUMMIT, SUMVO, ERBE, EMAXX & REVO 3.3
    Arkansas
    522
    If you only have one or two wheels that are wobbling, put one that is wobbling on a corner that is NOT wobbling. Drive it and see if it still wobbles. If it does, its the wheel if it doesnt it could be the hex.....at least start there.
    15,559
    Quote Originally Posted by Godspeed View Post
    Well that's okay. However, hex slop right out of the box is NOT a common problem as you stated in post number 3. It is a much more common complaint after a good bit of use. Since only one of your own hexes wobbles, I'd also not attribute that to the common wheel slop issue, since that would affect all of the wheels equally. You may have a problem with the hex's manufacture or installation, also not common complaints.
    Sep 2012
    225
    great info guys I'll build a stand for it and I'll check and see if the wobble is in the tires or the hexes. Great info here guys thanks again.
