    Jul 2012
    4
    Question Metal Jato transmission gears
    I want to make my car stronger on both inside and out. I am a pretty heavy racer and off roader with this car, and have just about replaced every bit of the outside. I am now wondering how to make the inside stronger. I know not to replace my spur gear with anything steel, but i was wondering if i replace all the gears in my tranny with steel gears, would that allow me to pop a steel clutch bell and spur on it? Plus the thing that really bugs me about the tranny is the differential gear. It has this plastic case to it and i stripped one of the screws putting it back together so now it leaks and i have to clean out the oil and replace it about every week. So either i want to replace my differential gear casing with metal, or i want to replace my entire tranny with metal so i can upgrade it to an entirely metal gear system. Thoughts, opinions, or help would be greatly appreciated.
    Dec 2009
    texas
    271
    Hot racing chromoly gears r the only logical option. They work great! I have four sets of them. No problems whatsoever other than lapping 3 out of the four sets in on initial install. Pretty much bullet proof.
    FASTEST "recorded/proven" JATO'S-3.3 AND Big block
    227
    Quote Originally Posted by bswift View Post
    Does the gears had hold up? Cause I had worn stock plastic gears of the tranny, I replaced them and I was playing last week and it just stop running but the engine was good the car just doesnt move and when I move the spur it gets stuck so I think I worn gears again and I'm thinkin of getting metal gears to stop worning gears.
    Sorry if my english is baaad.
    Jul 2012
    4
    The thing im worried about is the thing connected to the gears. like the plastic parts in between the gears. Since i do some off-roading im worried about shredding everything besides the gears since all that is plastic. Do you think that they will still hurt the inside?
