Results 1 to 3 of 3
    Dirty Jerz
    240
    many problems with my p4de. please help
    It all began when i broke my front center drive shaft and replaced it with a hardened steel one. while i was doing that i took the time to tighten my slipper clutch. I put everything back together and ran the truck. I stripped my delrin spur gear which was supposed to be stronger than the stock. I replaced the spur gear and noticed that after the truck was put back together the rear wheels wouldn't spin freely. Also when I turned the wheels by hand the slipper clutch wouldn't turn. i removed the rear slip diff assemble and it began its working fine. however when I put the assembly together it skips as I turn the wheels. I put everything together and now when i turn the wheels , front or back the center drive shaft and, spur gear and pinion dont turn. what could be the problem. could it be that my slipper is too tight. I back it out one full turn
    I play til something breaks
    central nj
    51
    rear diff bearings,sounds like what mine was doing when they went bad
    Saint Louis, MO
    504
    Check the bearings in the spur assembly.
