Results 1 to 15 of 15
    9
    jato 3.3 wont go (please help!)
    Hello, first of all i would like to say that i am new to the forums. ok so lets get down to the real problem... my jatos back wheels are like locked up? they wont spin the engine will start and everything but when i hit the gas it wont go. and also the clutch bell wont spin freely? please help.
    Nov 2003
    Long Island, NY
    2,602
    Did you check the clutch?
    Rustler-3.3,Revo-Hyper .21,Jato-3.3
    lots of mods
    9
    sorry, but how would i do that? this is my first nitro and its very frustrating
    Nov 2003
    Long Island, NY
    2,602
    Remove the clutch bull. There are 2 clutch shoes with a spring around them attached to the flywheel. Make sure it is all intact. I assume you checked the spur gear to make sure it wasn't stripped already?
    lots of mods
    9
    yup i checked the spur. and okay what if it is all intact?
    Nov 2003
    Long Island, NY
    2,602
    If the clutch is intact then it could be a problem with the tranny or differential. Does the clutch bell and spur spin when you give it throttle?
    lots of mods
    9
    no, it looks like they try to spin but they dont. and the gear that stick out of the chassis from the bottom (fly wheel i think) spins.
    Nov 2003
    Long Island, NY
    2,602
    If the fly wheel is spinning and the clutch bell isn't then it is most likely the clutch.
    lots of mods
    9
    also i can push it backwards but it makes like a click noise. and it just 100% refuses to go forward
    Nov 2003
    Long Island, NY
    2,602
    It is either the clutch, tranny, or differential. You need to start taking it apart to try and find the problem.
    lots of mods
    9
    okay, and how much do you think it would cost to fix? like under 20$? under 30$?
    oh and also, when i pick it up and try to spin one of the back wheels forward. that wheel will go forward but the other back wheel will turn backwards. (they wont both spin forward the same way).
    Nov 2003
    Long Island, NY
    2,602
    It is normal to spin one wheel and have the other one spin in the opposite direction. You should be able to spin them both in the same direction and it should cause the spur gear to spin.
    How much it will cost to fix depends on the actual problem.
    lots of mods
    9
    when i pick it up and try to spin both of them the same way they wont go. they try to but the clutch bell just wont move, but the spur gear trys to move
    Nov 2003
    Long Island, NY
    2,602
    I'll say it again, check your clutch.
    lots of mods
    9
    okay, it might have taken me a few days but i finally got around to checking the clutch. and the clutch shoes aren't worn down to much and the spring is still attached. and even with the spur,cb and clutch shoes off its still having the same problem.
