    Sep 2012
    13
    Need some gearing advice
    Hey guys newer to rc and I'm running a BL with 3s lipo on a 2wd slash. I want to stick with 48p so I can keep the gear cover. (I run in deep sand and dirt a lot). What are some good gearing options to keep heat down and also maintain a good amount of torque and speed? Let me know what you think.....
    Thanks guys
    40
    when I ran in the sand with my rustler I would run 19/86 with 3s and paddle tires. Still got pretty warm though. If you have a dremel and some shoo goo you can still use a gear cover. Now that I race a 2wd slash I run 32pitch gears with a home made cover. Running 15/52 gears at 145 degrees.
    castalia ohio
    5,293
    im running the stock brushless system on 2s with 76/23 gearing at 150 degrees
    Drag It!
    Sep 2012
    13
    Are you running in loose sand and dirt a lot thOu?
    castalia ohio
    5,293
    mines for general bashing. high grass, water, street, rocks, sand, you name it.
    Drag It!
    Sep 2012
    13
    Man the pinion just seems really high more for street use. I'm going to give it a try thou thanks alot
