Results 1 to 13 of 13
    3
    Need to identify model
    I was given this car from a family member and he thinks its an e-revo. I've looked around but can't find an e-revo that looks like it, I think it's closer to a summit. I need to repair some parts and would like to get the correct parts diagrams. Anybody know what model this is?
    Thanks!
    smthin
    Your back door
    200
    Summit.
    Sent from my LS670 using Tapatalk 2
    Picco .26 Revo
    62
    That is a summit. It has the locking diffs.
    9,794
    Summit. Moved from the 3.3 Revo forum.
    New York State: Snowbelt
    747
    Summit, has micro servos
    15,877
    Summit. Left side tires are installed sdrawkcab.
    Alt-248 on the number pad =
    3
    Awesome thanks. So as long as the part is for a Summit I should be good, correct? No submodel or anything?
    Thanks,
    smthin
    3
    Didn't even notice, thanks!
    747
    Quote Originally Posted by smthin View Post
    Correct, make sure it's for the 1/10th scale though
    Thanks,
    smthin
    3,094
    Its a summit
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    3,094
    Ok I guess im too late with that info.
    Thanks,
    smthin
    Im not sure of the model number but its the 2nd or 3 rd version/ edition. Got a picture of the radio?
    Version #11
    - am radio
    - standard evx2
    - tq4 radio am
    - T-lock module to controll the diffs
    - diffs later upgraded due to early breakage
    Version #2
    - 2.4 ghz 4 channel gray radio ( single model capability)
    - no t-lock module needed;
    Version # 3/upgrade?
    - 2.4 ghz black radio. High output LINK
    Version #4
    - newer 2.4 ghz antennae less radio
    -new " pro graphic" body colors
    - low voltage cut off evx2
    Iowa/ill/KS
    351
    looks 2.4, careful with the little screw on the beadlock rings if you switch those tires around. They are easy to strip out.
    Colorado
    304
    its a summit
