Wild Launch Still
I launch at about 40%. OK, I have : Trued rear slicks, locked the differential, added 3 oz. weight to nose, 0.94 springs in front, 2% toe in, level surface < just paved>, sugar water first 20', wheelie bar almost touching pavement. STILL launches hard to right after approx. 10'. Any more suggestions? Love messing with car but out of ideas!
Bob
Sounds like about 10ft out the power is ramping up on you again.. .. does it lift the front end again when it does the hard right? reason i ask.. some of out guys are getting a second wheelie down track when the power finialy kicks in full again... they added a bit more weight to the front... from 1 to 2 more oz's...
Are you running the rear dff locked? The wheely bar could be too close to the ground causing the diff to unload.
check your steering trim......roll the car up slowly to about 30-40mph and it should track perfect...if so then try swapping tires from side to side and see if that changes the situation.
Maybe swap left/right tires in case one is growing more than the other causing it to hook??
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
