Results 1 to 7 of 7
    7
    Summit EVX 2 esc dead?
    hi,
    a few days ago, when i went to turn on the esc in my summit, it turned on, and i had no throttle.. i still had steering and i could shift gears and lock the diffs but i had no throttle.. i took the body off and i saw the esc light wasent on but the reciever light was on. So, i turned off the truck and after waiting a few seconds turned it back on. I saw that the esc light would turn green for a few seconds, and then it would just go black.. does this mean that my esc is dead or is the motor burned out or what? i have tried re programing the esc, unplugging the motor wires, and i have tried unplugging certain servos from the reciever to see if it was just a bad servo.. and so far, nothing has worked...
    thanks
    Alma, MI
    12,283
    Have you hooked a battery directly to the motor?
    7
    no, because i dont have any batteries with that kind of connecter on them..
    Alma, MI
    12,283
    You should be able to put the motor leads into the TRX connector far enough to make contact.
    This only needs to be done for a split second... enough to see if the motor spins.
    Long Beach, California
    6,589
    and make sure do take precaution when you directly plug the batt to motor. have the truck off the ground.
    6,589
    Quote Originally Posted by Aking720 View Post
    hi,
    thanks
    could it be your battery? are you using lipo or nimh?
    7
    i just tested the esc with a voltmeter to see if it was pumping out any voltage and it is not.. and i did what you said and the motor is fine.. thanks for your help!!
