Results 1 to 13 of 13
    mn
    1,341
    A ton of NIP parts!
    I have another big lot of new in package parts. I would really prefer to sell this all as one lot but may sell seperate parts. I will list it all by part numbers. Looking to get $175 plus shipping for all of it
    4449 X2
    4146x x3
    4982
    1931 x3
    4931
    2381 x5
    3692
    4949x x6
    4660
    4191
    2754 x2
    4914
    4076 x3
    4964x
    3641 x5
    2334
    1884 x5
    4931
    5131 x2
    1953
    2530 x2
    3120
    4028
    5247 x2
    4431
    5381
    4430
    1952 x4
    1996x x2
    3189 x3
    5469
    4685
    4470 x2
    4708
    3229
    5380
    2721
    5278
    2728
    2716
    5211
    4948
    1936 x3
    2531
    3632 x4
    2632R x3
    1994 x2
    4191
    3195x x6
    4684
    2223
    4951x x4
    3120
    2545 x2
    4685 x2
    2640 x3
    1937 x3
    4936
    4576 x2
    5379
    2634R x3
    4928x
    2339
    3281 x3
    4982 x3
    3631 x2
    3652
    4120
    4995 x2
    3138
    4964x
    1853
    http://i490.photobucket.com/albums/r...une2012036.jpg
    stampede/sidewinder 5700 axial ax10 3905 e-maxx
    284
    Well, i was quite bored and decided to help you out. With the help of tower's search and ebay when tower didn't have it i came up with the list of the parts. Some of these i couldn't find as marked. Tops i would say their is 5 wrong in this list. If you buy just a part, don't take my word for it.. Look it up! (note: also the top part of the list is from
    cuda's list.
    traxxas fuel tank repair kit (4449)
    clutch shoes and spring(4146)
    tmaxx differential gear set(4982)
    Eagle or hawk a arms(1931)
    Maxx arms(4931)
    main diff gear rustler or stampede(2381)
    dust cover stampede(3692)
    tmaxx center drive shaft(4949)
    60t diff gear(4660)
    nitro pede gear box halves(4191)
    stub axle pins(2754)
    body mount posts tmaxx(4914)
    .12 recoil springs(4076)
    tmaxx carbon fiber disc brake(4964x)
    camber links(3641)
    2334
    Traxxas Turnbuckles 50mm LS2 (2)
    1884 x5
    Traxxas Drive Idler Gear Set
    4931 Traxxas Suspension Arms Upper/Lower T-Maxx (2)
    5131 x2Traxxas Upper Suspension Arms T-Maxx 3.3 (2)
    1953Traxxas Long Truck 1/2 Shaft Pro Pak (6)
    2530 x2Traxxas Bulkhead Front
    3120Traxxas Clutch Bell 32P 20T Nitro Hawk
    4028 Brake Support Bracket
    5247 x2 Traxxas O-Ring & Seal Set TRX 2.5
    4431 Traxxas Upper Chassis Deck Rustler
    5381Traxxas Diff Carrier/X-Ring & Ring Gear Gaskets Revo
    4430 Traxxas Lower Chassis T-6 Rustler
    1952 x4 Traxxas Stub Axle Housing (2)
    1996x x2 Traxxas Idler Gear 30T Hawk 2/Blue Eagle LS/LSII
    3189 x3
    Traxxas Header Screws 2.5x19mm Nitro Hawk (4)
    5469
    Traxxas Rod Ends GTR Shocks Revo (6)
    4685
    Traxxas Slipper Friction Pegs (12)
    4470 x2 Traxxas Spur Gear 32P 70T Rustler
    4708 NOT FOUND
    3229
    Traxxas Head Screw 2.5x10mm (6)
    5380Traxxas Front & Rear Differential Housing Revo
    2721Traxxas Differential Shaft
    5278 NOT FOUND- 5279 IS EZ-start-2 with motor something like that
    2728Traxxas Ball Bearings 5x8mm (2)
    2716Traxxas Differential Lube
    5211
    Traxxas Roller Clutch T-Maxx 2.5
    4948Traxxas Fuel Tank T-Maxx
    1936 x3Traxxas Truck Turnbuckles 46mm (2)
    2531Traxxas Suspension Arms Front (2)
    3632 x4Traxxas Caster Blocks Left/Right
    2632R x3Traxxas Caster Blocks Race Series 30 Degree
    1994 x2Traxxas Slipper Tension Spring
    4191 NOT FOUND
    3195x x6 NOT FOUND
    4684
    Traxxas Spur Gear 48P 84T
    2223Traxxas Battery Door TQ
    4951x x4
    Traxxas Pinion Gear 32P 21T E-Maxx
    3120
    2545 x2Traxxas Bellcrank Bushings (4)
    4685 x2Traxxas Slipper Friction Pegs (12)
    2640 x3
    Traxxas Chrome Suspension Pin w/Clip 44mm (2)
    1937 x3
    Traxxas Truck Turnbuckles 54mm (2)
    4936Traxxas Bumper Mounts Front & Rear T-Maxx
    4576 x2Traxxas EZ-Start Gear Set/Shafts
    5379
    Traxxas Differential Ring Gear/Pinion Gear Revo 3.3
    2634R x3
    Traxxas Caster Blocks Race Series 25 Degree
    4928xTraxxas Diff Output Yokes w/Screw Yoke Pins 2.5 (2)
    2339Traxxas Turnbuckles 105mm T-Maxx (2)
    3281 x3Traxxas Cone Split Beveled
    4982 x3Traxxas Differential Gear Set T-Maxx
    3631 x2Traxxas Suspension Arms Front (2)
    3652Traxxas Stub Axle Carrier
    4120Traxxas Clutch Bell Steel 20T
    4995 x2Traxxas Primary Gears T-Maxx
    3138VINTAGE TRAXXAS TRX NEW RC STEERING DRAG LINK 3138-(note got from ebay)
    4964x
    Traxxas Brake Disc T-Maxx
    1853 Traxxas Stub Axles Truck
    Once again, hope i helped everyone and the OP!
    mn
    1,341
    $120 shipped. The market must be in the toilet right now because normally this stuff would be gone.
    35
    How many differential ring and pinion gears do you have? Ill take them
    mn
    1,341
    No longer looking to piece it out. $115 shipped is the very best i can offer. Well, well worth this price. Like i said there is over $400 worth in parts here if you were to go buy it individually.
    mn
    1,341
    Any takers at this low price?
    mn
    1,341
    $110 shipped. At this price i'll only be coming out with $100 for the parts if that. Please, this must go.
    mn
    1,341
    No one interested?
    western Australia
    216
    pm sent to you
    modded 3906 e-maxx
    NJ
    59
    Pmed you as well !
    Sent from my EVO 4G LTE using Tapatalk 2
    mn
    1,341
    Still available. If not sold real soon it will all be going in the garbage. I am done wasting my time over $100
    mn
    1,341
    Apparently everyone on this forum is broke.
    15
    clear your in box
