Thread: jato wont idle
    jato wont idle
    I got used jato with a 3.3 it cant get it idle the only way it will idle is to adjust the throttle rod.so.it opens the carb a little bit but then it does when i hit the brakes the clutch spring looks good and tight i have tried adjuat lsn and hsn and idle.screw nothing seems to work and put 2 newer carbs on it tried going back to.factory setting then adjuat but it dont really help any thoughts
    1,967
    a few things...hairline cracks in the carb usually under the HSN.
    More than likely, you have a pressurization issue between the exhaust and the carburetor (including the fuel tank O-ring)
    I would replace the tank o-ring and hoses from pipe to tank and tank to carb. if you have a new O-ring for the carb base, I would replace that too.
    Just a few thoughts to hopefully help
    Middle River,MD
    84
    ur hsn (one that sticks straight up i believe im correct on the naming )should be at 3 turns from open since it is now broken in take the card off the gap should be a gap about the width of a paper clip the lsn one on side im not sure about id put that around factory
    Nov 2003
    Long Island, NY
    2,602
    Quote Originally Posted by dustyfingerz View Post
    3 turns form open could be way too lean depending on temps, humidity, etc. where he lives. 4 turns out should be the starting point for tuning. The lsn should be flush with the outer ring, and the idle gap should be .5 - 1 mm.
    Read the manual for proper tuning instructions and also see the links in this thread: http://traxxas.com/forums/showthread...our-TRX-Engine
    As Redsawacs said I would also replace all fuel tubes and o-rings.
    Rustler-3.3,Revo-Hyper .21,Jato-3.3
    lots of mods
    switzerland
    18
    have you tried to close your idle speed screw a little?
    15
    Look really close around the bottom of the carb and engine. if you see a little bit of nitro, then its prob the carb o ring or a hairline crack in the carb. Obviously remove to inspect. Hope this helps, the same thing happened to me. Perfectly tuned and all of a sudden BAM!!!! just kept shutting off. This fixed it!
