Results 1 to 15 of 15
    Jul 2012
    Granger, In
    185
    mmp sct 2400kv vs 3800kv
    ok guys, I am getting a castle for sure with the esc combo,but I still don't quite understand the difference between a 2400 or a 3800kv from castle, The site i will order from says both are good for 4x4 applications. What would you get for your pede?
    oh do I need the castle programming card or can I run it as is when I get it?
    Laredo TX/ Reno NV/ Palm Coast, FL
    272
    Yes on the card, I have the 2400kv on my converted stampede 4x4 and love it , my best answer too you is that the 2400kv is best for 3s lipo and up And the 3800kv is best for 2s lipos. The 2400kv is a monster! I do plan on getting the 3800kv setup for my exo terra, hopefully it will
    Do good.
    United Kingdom
    626
    If I recall this rightly....
    3800KV will have more torque less speed but run hotter...
    2400KV will have more speed less talk and be cooler....
    I think you need to run 3s-4s to get the most out of the 2400 it think where as the 3800 will be ok with good 2s LiPo's.
    Jul 2012
    Granger, In
    185
    Yeah I was doing more research and I'm getting the 2400, just bummed now cause its not in stock. Thanks thumper you just helped me make my choice concreate. Hurry up and get in stock already!
    Jul 2012
    Granger, In
    185
    thanks guys. sine I have a 3s I'd be better off with the 2400, might even go 4s with this combo!
    Wales in the UK
    5,832
    Get the 2400kv for sure just be ready for crazy times
    Jul 2012
    Granger, In
    185
    Well towerhobby had them in stock this morning, so I got me one. Can't wait.
    7,172
    Quote Originally Posted by mattstang2007 View Post
    You will not be dissapointed! It's a very good combo and a blast on 3S.
    BTW hope you have a good Lipo to run with the system. 125A min, 140A recommended, & anything more makes it a beast. Typically a 30c rated pack.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Rotterdam, Netherlands
    7,401
    Geared the same, the 3800 on 2S will give more top speed than the 2400 on 3S. The 3800 can handle 3S while the 2400 is specified for even 5S. On 4S the 2400 is a monster. 3800 is a great motor, but since the little price difference, the 2400 gives more power per dollar.
    Jul 2012
    Granger, In
    185
    I have a duratrak onyx 3s 6400mah 25c battery, hope that's good enough. Also what else do I need to make this combo work? I got the field programming card(i guess i need the cable for this?)and the castle shroud fan lol, I don't need a new transmitter or anything do I? thanks
    7,401
    The stock transmitter and receiver work fine with the combo. The field programmer connects directly to the ESC with the wire that goes into the receiver. You can connect the field programmer to a PC (with Castle Link software) with a mini USB cable to be able to use more programmable functions.
    Beware that a too tight slipper clutch can cause broken drive shafts or stripped wheel hexes. You might want to upgrade those to steel ones (Tekno, MIP or FLM).
    That battery should be able to deliver 160A, so that will be more than enough.
    Jul 2012
    Granger, In
    185
    sweet, thanks. I have the teknos on the way, rear only though for now.
    7,172
    The Tekno's are a very good upgrade. They have the 17mm adapters if you ever decide to move to the bigger hex's down the road to. This has to be purchased separately and will have to be by tekno also.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Jul 2012
    Granger, In
    185
    I was actually looking at the 17mm today, I think I'm gonna wait and see how aluminum 12 mm hexes work, after my stock ones break of course lol.
    Jun 2011
    North-West Ohio
    967
    Quote Originally Posted by o0wiz0o View Post
    That's not correct.
    The higher the KV the more speed but less torque.
    The lower the KV the more torque but less speed.
    Just to clearify.
    God is good.
