    Aug 2010
    4
    No more flipping, the cure.
    Hi all
    I believe I have the cure for the flipping Slayer. I have the original Slayer with the upgraded with the Slayer PRO suspension arms only. Not the chassis. Sway bar kit, and what I think is the fix are the Revo springs. I used the Traxxas Revo trx5439 Gold springs on the front and the trx5445 purple on the rears. I know alot of you will say they are way to stiff. Not at all, just the right amount of sag and the give alot of restance to bottoming out. The springs are shorter, just adjust the tension nut on the shock body to take up the slack. I used 5w30 motor oil in the shocks, but the back end is alittle bouncy, may try heavier weight oil in the rear end only, front is good. Drove it this weekend with this set up and couldn't believe how awesome the truck drove on road and in rough grave. Give it a try.......I know it will transform your Slayer. Traxxas should look at this set up it worked that awesome. Let me know if any of you try it yourselves. I have being messing with my Slayer for over 3 summers now. Now it is perfect.
    In a burning building
    8,588
    Motor oil. Hmm. I will stick with RC silicone oil and go with a heavier weight.
    Aug 2010
    4
    I know but it was all I had at the time, I will try 20 or 30w. But as it is right now you don't notice it when driving, just doing the drops test on the bench.
    naptown
    454
    I found 45 wt oil and some stiff springs and than a set of 12mm hub extensions is the way to go ran mine this weekend and was great only time it rolled was when I hit a dirt hill. I was really impressed. Actually power slides now and I run some aggressive 1/8 scale buggy tires.
    Riverton Utah, The Most Windy City in Utah!
    2,061
    I like the stock 30wt. I don't do much bashing, just cruising around on pavment and grass. Funny, I have motor oil in my Slash's shocks...
    Hippies. At least they save gas for real car nuts.
