Results 1 to 13 of 13
    Olive Hill, KY
    132
    proline pro trac ????
    hey all, got the proline pro trac with the mip x-long male bones....now it seems like my pede is really tight. you cant just push it and it roll smoothly now. a little bit about it real quick...started out life as a p4de, did the slash chassis conversion and also has the mmp with the 2400kv. it did fine till i did the pro trac upgrade...now it just seems tight. any suggestions...thanks in advance
    South of St Louis
    6,053
    Check a few things: with the truck up on a stand do the individual tires rotate smoothly?
    Does the problem get worse when the suspension flexes?
    Is the camber off with the protrac setup?
    Hurley, MS
    386
    What caster blocks are you using? I know a lot of guys including myself had to take a little metal off the casters or off the dog bones because they were rubbing. I would check that. Also when you add the protrac you have to get different male bones for the extra length.
    SUMMIT,EREVO
    P4DE,MERV
    Hurley, MS
    386
    My bad I just saw where you have the different bones. Long day.
    SUMMIT,EREVO
    P4DE,MERV
    Olive Hill, KY
    132
    seems like it is worse when the suspension is all the way down, like in a jump in mid air. as far as my casters go they are factory up front and rpm hub carriers in the rear. I didn't grease the mips like it says to, but I never did my orginal set either and never had this issue. maybe I'll try some grease tomorrow and see if that helps. just took it and rolled it on the ground also, still seems a little tight, especially when I pickup it up and let the suspension decompress, that's when it's the worse.
    Hurley, MS
    386
    ill have to take a pic and show you wherer i found a binding point. Digger ran into the same problem and did a similar fix.
    SUMMIT,EREVO
    P4DE,MERV
    Olive Hill, KY
    132
    cool i would really appreciate it
    Hurley, MS
    386
    it will be after i get home tonight from work.
    SUMMIT,EREVO
    P4DE,MERV
    Hurley, MS
    386
    You can't tell where I did the work without tearing apart. Are you still having trouble?
    SUMMIT,EREVO
    P4DE,MERV
    Olive Hill, KY
    132
    thats cool, yea its still doing it, this one has me stumped
    7,172
    Quote Originally Posted by kspec4 View Post
    I had to grind away a little bit on the inside of the front STRC aluminum steering blocks. It was a very minoot amount of meat from them. I grinded enough around to where they didnt bind at any angle. Being yours are plastic and if this is where they are binding you can take an Exacto knife and cut away until it doesnt rub. I believe Traxxas ones have the same issue to. I was lucky and the rear bearing carriers didnt catch.
    Another thing be sure you have the pin centered, the one that goes through the sleeve as best as you can. I know when i hunkered them down and i didnt hold force the grub screw would move the pin up a little. Using a pair of channel locks over them would work well to.
    Hope this helps.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Olive Hill, KY
    132
    thanks ill check that this evening
    Hurley, MS
    386
    Thanks Digger for clarifying!!!
    SUMMIT,EREVO
    P4DE,MERV
