Running Mamba Pro Max 5700 with 3s Lipos. Tires keep coming off eveni my beadlock dirt hawgs! Any suggestions?
Get a rim that takes glue?
front and back? do you have a center diff?
***You Build It ...I'll Jump It!!!*** OS .18 TZ; Trinity Pipe; HCR Titanium Skid Plates & Bumpers; Futaba S9450 Throttle Servo; Airtronics 94358Z Steering Servo; RPM A-arms & Knuckles; FOC; Lunsford Titanium Hinge Pins,Turnbuckles, Push Rods & Rocker Posts; New Era Roll Bar & Engine Mount; Proline Mashers on Velocity Rims.
I have to agree with jimmie, I finally gave up on beadlocks when I'm running 3S. You also need a really good glue job on glued rims if you're doing speed runs on pavement. The centrifugal force yanks the tires away from the rims pretty hard!
Merv: Neu, MMP
Center diff is installed. Will try to scuff up the beadlocks. It was crazy, it took the front tires off in like 15 seconds! And it was on dirt/tanbark. Is actual tire glue the best or rubber cement?
CA glue (Karzy Glue, Super Glue) is what is typically used. Don't use rubber cement.
i use krazy glue advanced formula and it has held up on 65mph speed runs .even runs where i hit the throttle too hard on a speed run at 50 causing major balloning!
Glue the tire to the bead locks it worked for me
Powered by Castle
beadlocks are junk, they are ok for a rock crawler that doesnt see speed.... they can not hold onto a bead like a wheel/tire that is glued....
glue the tires to the rim
Love how Noobs ask a ?, then say you're wrong
