Page 1 of 2 12 LastLast
Results 1 to 40 of 48
Thread: Racing slash
    FT Stewart, GA
    74
    Question Racing slash
    I need some assistance, I am trying to get my Slash race ready and need some advice. My setup is:
    Pro-line transmission
    Pro-line protrack
    Pro-line steering
    STRC LCG kit
    STRC shock bodies
    STRC rear bearing carrier
    STRC front block
    Anzio rear shock tower
    Castle ESC and motor
    Losi silver springs rear
    Stock spring front
    Losi 35wt front and back
    My biggest problem is that I can't keep the back end straight on power and out of turn. I have tried different tire but I think it's my oil and springs. I don't want to give up on the truck but I want to be competitive.
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    Nov 2011
    North Central OH
    1,047
    Rear toe in is important!
    Slight toe out in front will put a slight load outward on fronts to stabilize front tires from wobble
    You may need less slipper dialed in to allow a more gradual acceleration. If the tires don't hook up then don't use so much throttle, wheel spin does not equal forward acceleration.
    What tires are you running? What compound and what is the track surface you are running on?
    South of St Louis
    5,994
    Is the proline differential causing you to slide out of the turns? Maybe it needs an adjustment.
    San Jose, Costa Rica
    704
    I think change differential oil can help.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    FT Stewart, GA
    74
    I'm running PL slider soft in the front and I have been switching between PL Caliber soft, Jconcept subcultures super soft and stock Losi SCTE. BTW the Losi seem to grip the best. Also I have a STRC 1 degree rear carrier that I'm thinking about adding to give it addition straight line bite.
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    South of St Louis
    5,994
    Do you know how many degrees of camber you're running now on the rear?
    FT Stewart, GA
    74
    I have 1 degree of camber both front and back.
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    13,227
    Check what tires the fast guys in your class are using.
    FT Stewart, GA
    74
    Would the PL Protrack and the STRC 1 degree rear carrier be to much too much toe?
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    FT Stewart, GA
    74
    Any sugestions on what losi springs I should be using?
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    castalia ohio
    5,321
    well i was watching a video by jang and he used losi xxx green springs in back, and silver springs in front.
    Drag It!
    13,227
    Yea, start there, and here is a chart on where to go from there:
    http://www.ultimaterc.com/forums/showthread.php?t=17347
    The extra toe will help you get out of the hole in a straight line better.
    31
    Shock-springs/oil weight have nothing to do with turning. Shocks are for the jumps and bumps, period. Toe, camber and upper-rod positioning are the keys to making turns. Tire selection also comes into play.
    castalia ohio
    5,321
    Quote Originally Posted by Old Ezra View Post
    and your basing this off of what? shocks and springs also control how much body roll you have in corners. if you have to week of spring it will have to much roll therefore lifting the inside tire, if you have to heavy its just going to slide and not hook up as well.
    so please tell us oh great one on how it has absoulutely nothing to do with turning?
    if you still dont believe me then just read this
    http://www.circletrack.com/chassiste...s/viewall.html
    Drag It!
    South of St Louis
    5,994
    I have a set of green losi springs on the front, blue on rear, on my P2de and race Sl2sh and they work really well.
    The greens are maybe a little soft for bashing with the Pede but perfect for the dirt track.
    Aug 2012
    36
    Perhaps things are different in the RC world, but physics is physics, so I doubt it, and in the real world springs and shock damping have a large impact on cornering. Anything you can do to combat body roll and keep your tires flat on the ground will help you corner better. Period.
    13,227
    Shocks springs and oil have everything to do with turning period lol...
    castalia ohio
    5,321
    haha, tell him guys! lol
    i read that and was like are you kidding me? lol
    oh well it happens
    Drag It!
    South of St Louis
    5,994
    One of my Slashes has springs so hard they could hold up a house.
    In a search for less body lean on turns I went a little overboard but it flips less often.
    castalia ohio
    5,321
    did you think to try progressive rate springs? or duel rate?
    Drag It!
    Aug 2012
    36
    Doesn't that hurt you on traction though? Every surface is different of course, and I don't know what you're running on, but when I stiffened up my son's Slash on loose dirt, he'd spin out quite a bit due to lack of traction. Of course he didn't flip as often, but I still need to find the sweet spot for him.
    castalia ohio
    5,321
    dont forget about roll bars either. and for people that never thought about it rpm makes the duel stage pistons so you can tune your suspension even more. instead of just one rate for compression and rebound with 1-3 holes and whatever weight oil you run you can set it up so that say it has a 1 hole compression speed but a 4 hole rebound so it recovers faster. just something to think about for anyone big into racing of any sort.
    Drag It!
    Jan 2008
    South Jersey
    8,259
    Wow! This is definitely a first for me!
    So, say hypothetically I'm running paved or even dirt oval. Should I just take the shocks off of my truck and replace them with solid camber links?
    The funniest thing is that most, if not all the oval guys I know run different spring/ oil combos from side to side, if not on all four corners. Why would they do something like that if shocks had nothing to do with turning?
    castalia ohio
    5,321
    where is the like button when you need it harry697? lol
    heres some vids that will help you out probably.
    Drag It!
    castalia ohio
    5,321
    Drag It!
    castalia ohio
    5,321
    Drag It!
    FT Stewart, GA
    74
    This is a lot of info, back to the LHS I go, lol. Thanks
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    castalia ohio
    5,321
    no problem, hope all this info has helped you so you dont need to buy parts again to try and get the setup you want. an assortment of springs, oil, and preload adjustments (if not threaded) are always good to have around so you can tune without having to go to the hobby shop over and over again. tires are one thing you may need to have multiple sets of to get the proper ones. but you can avoid this by asking around and finding out what tires the fast guys run.
    Drag It!
    FT Stewart, GA
    74
    I'm still up in the air on shock oil weight, I think I'm going to try 35 front and 32.5 back.
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
    Jan 2008
    South Jersey
    8,259
    Quote Originally Posted by adonismp82 View Post
    Sounds like a good place to start with 2-hole pistons.
    South of St Louis
    5,994
    Quote Originally Posted by PushRod View Post
    I don't run offroad much, almost all pavement except for my track sl2sh which has much softer springs. So the stiff ride was for speed runs up and down the street.
    castalia ohio
    5,321
    i personally wouldnt start with less than 40w myself.
    Drag It!
  33. #33
    FT Stewart, GA
    74
    Quote Originally Posted by 08kgraves View Post
    I also have a Losi 4X4 and it weights more than my Slash and we use 35w or lighter weight oil. Why do we use a heaveir weight oul on a lighter truck? Now i know that comparing Losi and Traxxas is like comparing apples and oranges but the concept is still the same.
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
  34. #34
    13,227
    It depends on how bumpy the track is. If the surface has ruts, and/or is very bumpy, without large jumps, 30-35 wt oil is not out of the question, even on a slash. Just remember that the springs need to be matched to the oil...
  35. #35
    FT Stewart, GA
    74
    I'm running it on an outdoor 1/8 scale track in San Antonio Tx, medium jumps. The fast guys (2WD SC) make around in about 35-40 sec. S maybe I should go up to 40wt +.
    Brustler
    Slash
    E-Maxx
    1/16 E-Revo
  36. #36
    South of St Louis
    5,994
    Yea they didn't work very well on the track. They quickly went to my bashing slash
    I'm now using losi green-front, blue-rear and that seems to work pretty well. But, the front almost feels too soft coming off jumps.
  37. #37
    31
    Read-on there you professionals-I know it's a lot to take-in........LOL...........you just might learn something. Pay the most attention to fredswain's posts....
    http://www.rctech.net/forum/electric...ber-links.html
  38. #38
    31
    This ai'nt circle-track.......camber-links control roll, or as you call it body-roll...........the body don't roll....
  39. #39
    31
    Quote Originally Posted by harry697 View Post
    I'm not talking about going in circles. I have no clue to be honest, on the subject. I'm talking off-road, SCT. I get dizzy LTO'in
  40. #40
    castalia ohio
    5,321
    ok fine, then how come in torc racing (the off road championship) the people running out front personally say that they could do so because they had the proper shock/spring setup for the track?
    ill just leave it at that. im not going to bother arguing with you and your 26 posts that i guess made you know everything when you have multiple other people saying the same thing.
    yes these other things matter as well that you are saying i wont deny that one bit, and im sure nobody else will either. but to say that shock oils, spring stiffness and anything to do with the shocks themselves have nothing to do with getting around a track faster you are dead wrong. and if you think so then how about you take a lap around a track with no shocks or springs even on your car and see how well it works out for you? you can post a video for us as well to prove that it did not affect anything what so ever. this is extreme yes but for example is the same as having to light of a spring and always bottoming out from anything. bottoming out slows you down. spring stiffness will matter even more for the size of the jumps. the bigger the jumps and rougher the landings the stiffer the springs you will need. and then shocks controls spring movement. so to light of oil and your car will be bouncing all over the place. to heavy of oil and your car cant absorb the landings like it should.
    these statements i have just made are not opinions they are facts of many things including physics.
    Drag It!
