Results 1 to 21 of 21
    Ontario
    41
    Pinion and spur size
    I have tried every combination I can think of to keep the motor and esc cool. I am running stock esc and stock motor on 2 2200 40c lipos in parallel. Can anyone help me from always overheating after only about 10 minutes of running. I mostly run on pavement and loose gravel. Never on grass because it overheats almost instantly.
    Alma, MI
    12,281
    I am assuming 2S LiPo's?
    What size tire?
    Tire size plays a big role in gearing.
    Another thing to check is proper gear mesh.
    Too tight will heat things up quick.
    Ontario
    41
    The tires are proline speedhawgs on Titus bead locks. I know the bead locks make it heavier but it is all I have for now. When setting the gear mesh I always use a piece of paper to adjust it. And yes they are 2s lipos.
    Feb 2002
    4,613
    the heavy beadlocks and extra battery weight are what is making it hot.......
    Alma, MI
    12,281
    Most of your overheating issue is due to the locks.
    I ran 2S 2200's in parallel as well....
    stock motor, stock ESC, buggy rear Hawgs on Axial Rebels...
    23/50 gearing; no heat issues on pavement and dirt.
    Even in 100F ambient temperatures.
    so cal
    9,244
    Try gearing down until you get lighter rims. Like 23/50 gearing
    what gearing are you running now?
    Ontario
    41
    I am running 23/50 at the moment but I have tried many other different variations.
    so cal
    9,244
    I.would maybe go 55 t spur but the rims are the problem
    Do.you have the stock rims and tires, heatsink and fan on the esc? Will help but wont solve the problem
    Ontario
    41
    I have the stock tires and rims but they are pretty trashed. I will try a 55 spur for now and go to my Lhs tomorrow and order new rims. Would a mamba max pro esc help at all??
    so cal
    9,244
    The mmp will not get hot and will help.
    do you have a temp gun and ever taken motor temps?
    Ontario
    41
    I don't have a temp gun. It is something else I wanna get.
    so cal
    9,244
    The esc normally is the weak link and the motor can handle it better.
    Mmp also has a lot of tuning options that will come in handy don't forget the castle link!
    Ontario
    41
    I have been looking at getting the map for a while now but until recently I was running nimh's and didn't think it was nessesary but I think now is the time to get it. On a different topic I was just changing the spur an noticed that my slipper is seized to the little disc. Has that happened to anyone else. It's like I don't even have a slipper anymore. And is there anything I can do to prevent this in the future??
    so cal
    9,244
    Sounds like it was slipping too much and overheated.
    what setting did you have it set at. The heavy rims didn't help that either. I have a powerful neu motor and have ran 65 with no clutch problems
    Ontario
    41
    That's what I was thinking but wasn't sure. I guess I need to order one of those too when I order new rims.
    so cal
    9,244
    Yep maybe a 50t spur when you get the rims too.
    one good thing it will be easy to remove the tires from the rims
    Practice makes perfect even with gluing tires!!
    Ontario
    41
    Yeah that's why I like the bead locks that and I'm not very good at glueing the tires.
    Ontario
    41
    Is the hpi 2196 rim good?? Is it light enough??
    so cal
    9,244
    Hpi 2160 or 2140 or 2196 area few good 2" rims for the wide speed hawgs.they have some much needed offset that's helps with roll overs.
    the 2196 not as much offset but still good!
    Ontario
    41
    Thank you 50 you have been a big help as usual.
    so cal
    9,244
    Your welcome! Anytime!
