Results 1 to 14 of 14
    Jul 2012
    24
    6 pad slipper clutch?
    Hello,
    I recently converted my summit to brushless and it has allot of torque.
    And the stock slipper isnt holding up to the task.
    I know there is a 6 pad slipper out there but where can i buy that 6 pad slipper?
    who has the product number or a store where i can buy that thing?
    PS sorry for bad english
    Toronto
    2,324
    I'm not sure, but look in to what the E-Revo uses, and that should work just fine. If it's the same setup, then you need to figure out where to set it - loosen it or tighten it. GL!
    Jul 2012
    24
    Gonna order the have duty slipper from traxxas for e revo.
    Jul 2012
    24
    heavy duty*
    Nov 2011
    73
    Hot Racing makes the double up clutch that can use 6 pads. Also might want to look at Robinson Racing slipper clutch but it has a dedicated metal spur gear.
    Mount Airy, aka "Mayberry" North Carolina
    347
    I also saw a mention a while back about someone using a clutch disk from a fuel car. Requires slight modification but it gets you plenty of contact area. I'll start digging
    The Kid
    14.4 Dewalt & Misc. el-cheapo mods
    San Jose, Costa Rica
    704
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    Sep 2009
    Victoria B.C Canada
    5,076
    Not sure if this is the right one but
    http://traxxas.com/forums/showpost.php?p=5006636
    Sent using lipo power
    Mountains cant stop me
    they have tried
    347
    Bingo !! U da Jamann !! That's the post I was talkin' about
    The Kid
    Jul 2012
    24
    jamann & kid yr the best gonna use that disk clutch. @ other ppl tnx for the input
    15,460
    A couple notes:
    The disc brake is thicker than the original pads, and the thickness varies from one disc to another. You may be required to clearance (sand down) the inside of the gear cover so the spur doesn't rub. Alternately, allow the spur to rub and it will quickly do its own clearancing.
    I've had a disc cause spur gear wobble on one truck. I don't know why. I have not tried that particular disk on another truck.
    Alt-248 on the number pad =
    Sep 2012
    221
    I think this is what I need, I do lats of back and forth on concrete popping wheelies and stuff I'm noticing it is slipping now...
    Sep 2012
    i had the same problem ,so my hobby guy gave me a disk brake from an emax ,dremel the holes and its awsome.Now it will pull a wheel now on 7in mud slingers on rc4wd alumin wheels
    Sep 2012
    221
    Quote Originally Posted by faq24572 View Post
    sweet I will look into this the next time I'm at my lhs.
