Results 1 to 3 of 3
    Granger, In
    185
    Changed piņon have a question
    So had a heck of a time getting the stock pinon off, but I got it. So I have the 9t in and the truck rolls but not near of far as it used too, i am sure the lower teeth count help to slow it down too, but seems to go fine then when the throttle is let off, it stops within, I would say around 6-10 feet without using breaks. If I do use brakes it stops very well. So to the questions, do you guys think I tightened the motor to tight to the drive shaft? I just don't want to have it to tight and burn the motor out. other then that, truck is even more awesome lol.
    This post has been edited for bad language. If you type something and it turns into a series of *'s you need to edit the post to remove the offending language. Please keep language squeaky clean and suitable for all members.
    Dadx2mj
    May 2005
    Minnesota
    983
    How is the mesh between the gears? Did you shim with a piece of paper?
    2x Stampede VXL
    Stampede 4x4
    Granger, In
    185
    mesh seemed good, no didn't use paper.
