Results 1 to 15 of 15
    Jun 2011
    54
    fixing a bent drive shaft
    hey guys this is my way of fixing a bent drive shaft i would appreciate it if you could take a look at the video . thanks
    http://youtu.be/co3fcA7PMDA
    Australia
    3,257
    That link wasn't working for me...is this the vid you tried to post?
    Rock n Rolla !
    HESPERIA, SoCAL
    248
    That's the video. Link worked for me.
    Australia
    3,257
    Quote Originally Posted by YFZBOB View Post
    I tried to watch it at work...it may have been blocked. Thanks mate
    Rock n Rolla !
    HESPERIA, SoCAL
    248
    No Worries Mate! Hate when they block my favorite sites.
    Quote Originally Posted by craig.mitch316 View Post
    Jun 2011
    54
    thanks for fixing it. i want to ask a question my pivot balls keep coming out of the carriers how can i stop this?
    495
    what carriers are you using?
    Jun 2011
    54
    Quote Originally Posted by hottrodd1090 View Post
    Rpm carriers
    90
    Lose the RPM carriers, the stock once work just fine and is cheap and easy to replace.
    495
    mine kept popping out too and i put the front stock ones back on.i tried taking the metal ring off the stock ones and putting them on the rpm ones but it made it too tight.to get the pivot ball to move freely i had to have it really loose and that caused alot of play in the camber of the wheel.
    232
    In the video, doesn't he put the cvds in backwards? I though the red part was suppose to go by the diff?
    EMBE build in progress!
    Apr 2009
    380
    Only on the center diffs, the dogbone outdrives go on the diff output, the RED ring is on the side with the threaded shaft that fits into the hub carrier.
    However, sticking a driveshaft in a bench vice won't fit it, you'll need to gently over bend it in the exact opposite direction of the original bend so it sets back in place.
    Just clamping it flat won't remove the bend completely, depending on how bad it is it may make a good improvement or nothing at all.
    For the record I use MIP Spline CVDs and Traxxas centers.
    232
    Quote Originally Posted by 65535 View Post
    Thats what I thought haha. Does anybody know if the emaxx center cvds will work on the e revo? They are $10 cheaper.
    Apr 2009
    380
    I don't believe they will, I think the transmission is in different locations and overall size is different enough to keep them from fitting.
    Jun 2011
    54
    Well I used the bench vice and it works like a charm. My driveshaft came out perfectly straight and after hitting a couple of huge jumps nothing happend so far. so I think it worked pretty good.
