Results 1 to 24 of 24
Thread: big motor
    Nowhere, Québec, Canada
    353
    big motor
    Hey guy!
    So I was thinking about changing the motor of my pede 4x4 vxl. Why you ask?
    I'm tired of overheat issue with 3s lipo. So I want a bigger motor. (It will reduce the heat, right?)
    I would like to have a lower kv motor, so I can increase the speed range:
    -9t pinion, low speed for off-road, bashing, wheelie, grass, mud, etc.
    -22t pinion, for high speed run. 60-65 mph is perfect for me.
    I calculated with this that I need a 2800kv motor to reach 60 mph with a 22t pinion. What do you think about this?
    delaware
    937
    i would recomend a 2400 castle and up the voltage and then you could really change the gearing option to suit what you want to do
    353
    2400 castle with a 4s lipo? sound good to me. Any other recommendation?
    midwest
    303
    Quote Originally Posted by emmanhello View Post
    I would choose the 2650 instead of the 2400 or better yet the larger 2200...
    Wales in the UK
    4,407
    Yes put a 2200kv monster in your pede no more heat probs ever
    Austin, Texas
    970
    Castle is not the only motor you should be looking at. The "4065" number is the length/diameter of the can. I can only speak for the leopard which I run 15/52 on 3S with a MMP and motor stays around 120 no matter how hard I run it.
    Leopard 4065 2700kv - $80
    ********* 4168 2650kv - $52
    ********* 4268 2350kv sensored - $60
    Tacon 4071 2650kv sensored? - $72
    Castle 3670 2400kv - $115
    353
    I made my choice, I might go with a Castle 1415 2400kv and a mamba max pro with a 4s lipo. What do u think, guys?
    Is there anybody with this setup that can give me some advice? Any trouble fitting the 3670?
    Louisiana
    618
    Just got my 2400. Will be running 3s
    353
    Quote Originally Posted by josh62685 View Post
    When you're done, can you tell us how went the installation? You'll probably need to dremel some plastic....
    Louisiana
    618
    Sure I will update. From pictures of others it looks like I will have to mount the mmp where the reciever goes.
    353
    Here's a video I just watched that might help you fitting things in place:
    Wales in the UK
    4,407
    looks like you made a good choice with the 2400kv and with 3s it will run cool and be fast and if you want mental you can try 4s...peace
    12,367
    If you can find one, a castle 1512 1800 is a good option for 3-4s option:
    The chassis needs a little rotary tool work to fit:
    This motor is the same dimensions as the castle 2650kv.
    Whats in my wallet?
    I cant afford a wallet...
    Salisbury, NC
    633
    [QUOTE=Slaughter33;5324410]Castle is not the only motor you should be looking at. The "4065" number is the length/diameter of the can. I can only speak for the leopard which I run 15/52 on 3S with a MMP and motor stays around 120 no matter how hard I run it.
    Can I run a Leopard motor with my stock ESC, or should I order their combo to try it? If I put that in, does the programming still work on the stock transmitter?
    Jun 2010
    Miami, Fl
    6,731
    If you want to run 1/8 motor you need something more powerful than the stock Esc, at least Mmp, if not you will burn it.
    Louisiana
    618
    OK I got it mounted and am happy with everything's location. I dremeled half of the reciever box so I could mount the esc there. To me it looks good.
    Austin, Texas
    970
    Nice job on the ESC mount. Should get good airflow and stay a little cooler than down in the chassis. I might have to steal this idea
    353
    Great! How much did you paid?
    Just one thing, you're not waterproof anymore....
    Louisiana
    618
    I have a brushed 2wd Pede that I use for my water needs
    Combo was 230 at tower hobbies and 30$ off coupon. So I paid 200$
    Wales in the UK
    4,407
    Love the way you have setup your esc man that will keep things nice and cool...peace
    353
    YESS!
    I received my MMP with 2400kv. Installation was easier than I thougt!!!!
    I'm really happy because I still can choose between 9t and 22t pinion
    12,367
    Josh, great idea to mount the esc...
    Whats in my wallet?
    353
    lol, don't worry, duck tape is temporary.... Just need to find how to fix it
    Wales in the UK
    4,407
    Cant wait to see your next vid with that power house setup manTell us what you think after a few runs..............peace
