Results 1 to 7 of 7
    26
    dts-1 TQI link app problems
    It seems many of us have had problems getting the tqi link app to work. Heres what I did. Use a differnet trans to avoid unbinding while running. So just bind the trans. to the tree and update it. to start, always traxxas link app first, then trans ,make sure icon turns greeen on ipod,then turn on tree quickly,check too see green icon for tree on ipod, then press set on tree untill 2 beeps sre heard.then turn on trap within 10 seconds, check diagnostics and all should be working now, the only difference with this method is you will need to link the tree to the trap each time by pressing tree set button as described , Good luck !
    Traxxas Employee
    Plano,TX
    55
    If at any time while running the DTS-1 the system becomes un-linked from the TQi transmitter, all you have to do is go back out to the main screen on the garage and then choose the connect icon, set the transmitter to link mode, and then hold the set button on the DTS-1 starting unit until it beeps and goes into link mode. After doing those two things, the transmitter and the starting line module will link back together.
    26
    The first lasers on the my trap the car goes accross has a spread out vertical beam as opposed to a precise dot on all the other lasers.By the time the reflectors are about 8 feet away, the beam fills the whole reflector .Does your trap do that ?Thanks,
    Quote Originally Posted by shutterm4 View Post
    26
    Sometimes i get an error (unlink) message when sending a comand to the tree (this happens if i take a break for 10 -15 min), I just resend the command and it works as normal.Try that first...its quicker
    Traxxas Employee
    4
    I would contact Traxxas. It sounds like one of your lasers isn't functioning properly. Please call 1-888-Traxxas.
    Jun 2013
    Loughborough, UK
    mdasasdasd
    as
    Quote Originally Posted by TrxRichard View Post
    Fort Dix NJ
    38
    sounds like the lens on your laser needs to be adjusted...... not something you should have to do
