Hey guys,
on my merv, the brushless setup isnt working right. have any of you guys had this problem where the trucks steering works fine, but when i go to give it throttle it glitches. not the type of studder when only 2 wires are connected, but its like if i hold the throttle lets say at 50% and dont move my finger, the throttle response on the car will rev up to that speed, but then go to neutral like once a second. i can even see the light on the aftermarket esc change colors indicating that i was doing neutral in between throttle, but i wasnt. it does this in forward, brakes, and reverse. it will constantly go back to neutral about once a second unless my current command is neutral. steering works fine 100% and range is not the problem because im using 2.4 and i have tried it with another radio with the same results. the only thing that fixed it was using a different esc. is my reciever connection bad? i already tried re-soldering those... there was a dent in the wires so i thought that was the problem, so i took it out and the problem remained. any help? its really annoying i want to enjoy my new merv! Thanks!
