+ Reply to Thread
Results 1 to 14 of 14
    93
    Aftermarket bulks and diffs
    Does anybody make aftermarket diffs and bulkheads for the merv. I would prefer to stay away from the aluminum ones but if that's all that's available what's the best.
    Sent from my iPad using Tapatalk HD
    St. Louis, MI
    8,160
    There are no aftermarket diffs.
    The aluminum bulks are the only aftermarket available; there are quite a few threads on "which is best". Dig down a few pages and I am sure you can find at least one.
    recalculating...
    564
    I don't think you will have any issues with the aluminum bulkheads, shim your diffs and they should hold up better.
    I like turtles.
    Oct 2011
    190
    from what i have read the hot racing is the best because it actually locks together like the stock while i guess the others dont?! im not sure. i still have stock but have been looking into it as well. and jimmie is right search a little and you will find the answer
    so cal
    9,245
    I run gpm mainly because the toyz deal 109 for front,back and trans case but no problems without the bolt. I am running a neu motor and big tires and once shimmed properly I haven't had any problems at all
    north van canada
    512
    shimmed the stock one then never had an issue
    Powered by Castle
    93
    Thanks for the info. I have shimmed mine with the stock bulk heads and they have done fine for a while but finely gave in to the big block and canyon tires. May just re shim with new pinions and see how long they hold up again before dropping the $ on the aluminum bulks.
    St. Louis, MI
    8,160
    Be sure to shim once again after a few packs. Sometimes they need it after a break in period, sometimes they don't; 50 figured this out.
    Australia
    29
    I was fed up with the standard bulkheads and diffs going all the time. Since I fitted the hr rear bulkhead and shimmed I have had no issues, just need the front one now !
    I highly recommend the hr alloy bulkhead it's fully closed so no dirt or in my case sand gets in and chews the diffs up.
    I run a mmp with 5700 motor
    so cal
    9,245
    Thanks Jimmie!
    No doubt hr bulkheads work! Did you shim your used ring and pinion or was it new?
    Feb 2002
    4,519
    Quote Originally Posted by multidookey View Post
    actually the HR lock together on the front and the back of the bulkhead, even further improving over the updated traxxas stock
    the integy and gpm don't lock together at all. they are like the original (not updated), stock traxxas bulkheads
    the
    Love how Noobs ask a ?, then say you're wrong
    so cal
    9,245
    From what I see aluminum bulkheads don't need that bolt. Haven't had a single problem with my gpm bulkheads
    Aug 2012
    7
    I have aftermarket diffs ,
    I machined some out of allu
    Works great !
    so cal
    9,245
    Like to see a pic of that! How long did it take?
