hi everyone, finally im working a little more, so i get to spend a little money on my hobbies, and been wanting to get stuff for my slash 4x4 for a while, but i have some questions before i do
1) im thinking about getting 1/8th tires for my slash, though its still the stock system in it, havent upgrade to the mmp yet, but will eventually. i remember seeing a thread where some one mentioned that 1/8t tires balloon less and will handle better, and possibly help with higher speeds (i don't expect a huge increase, but i do speed runs with the high gearing and a 3s) i do mostly bashing on a 3s, so if 1/8th tires are better, ill get a set
2) the heavy duty revo spec slipper clutch kit, i want to get that as well as the aluminum bearing adapter, but im not 100% of the heavy duty revo clutch kit, i don't want to buy the wrong thing, i think this is it though
http://www3.towerhobbies.com/cgi-bin...&I=LXZUH8&P=ML
3) paddle tires for snow? yes or no? if i end up getting 1/8th tires, should i get 1/8th paddle tires?
4) and since i plan on rebuilding the slipper clutch, i want to get a new 54t spur gear, it has a wobble, that i would like to get rid of, its a cheap part so i might as well replace it, but last time i got a spur gear, i ended up buying the center diff spur gear and it wont fit on the slipper, not even close, so if someone can please link me to a proper spur for the slipper clutch, it would be great.
thank you for any help you can provide
