Page 1 of 2 1 2 LastLast
Results 1 to 40 of 51
    San Jose, Costa Rica
    637
    Lightbulb My Mamba monster Slash
    Hello:
    I wanted to share with you (If you didn't see the Kitteh298 post) My Slash with a mamba monster combo.
    First started like a very unusual idea I had, but thanks for Kitteh298 I had the inspiration.
    Here are somes pics:
    First I Changed the Gearbox to a Hot Racing gearbox(personally, I really like that gearbox):
    The gearbox mounted:
    The ESC:
    The first pic was before mount the motor
    This is the actual picture (Is in that position because the motor wires are very shorts)
    I attached the connectors(I really dont know why )
    Continued...
    Continued…
    Now, my "Little" friend, and my homemade cooling fan (Again, I really dont know why, just for be safe the motor is cool )
    Protection:
    The next pics are a bit old, maybe later I am going to update the pics:
    And that’s it
    My gearing is: testing 68/14 in 32p
    Batteries: 2x NiMH 8.4v 3000mah(Very decent power)
    Everithing is stock(suspension, driveline,....etc)
    My next upgrade is adapt my old watercooling system for my Mamba Monster Combo, LiPO battery, and maybe this driveshafts.
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    Ok, today I tested the 14/68 gearing and is just very slow, maybe i am going to change to 14/58 or 17/58 or 20/58 and see what happen.
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    I changed the gearing to 14/58 and was a lot better, is faster than 14/68.
    My next test is 17/58 and 20/58
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Grassie Ontario Canada
    2,308
    Quote Originally Posted by DBG View Post
    Can you clock the speed ?
    1,824
    Awesome thread! The slash chassis is so versatile. Coming from a guy with a 2wd Stampede with the 2400 combo, I have to ask, how is that hybrid axle setup working out for you? 2wd steel yokes with 4x4 axle shafts? And how many packs have you put on them like that? Thanks in advance
    637
    Quote Originally Posted by Oaks View Post
    Thanks
    Yep, the slash is a very nice plataform.
    I am using the stock shafts (yes the stocks ones ) with the steel outputs, but i am not using the slash 4x4 axles and i think the steel output yokes doesnt fit with the 4x4 axles.
    I ran like 5-15 packs with the MMC and 20-25 with the velineon and 5-10 with the stock titan. The axles already have signs of wear
    I suggest dont run the slipper clutch very tight and have throttle control.
    I suggest use the 4x4 axles or mip axles or maybe this axles:
    http://www.ebay.com/itm/190701014362...#ht_1745wt_772
    If you have more questions, let me know
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    With a gps, no
    But in theory, yes
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Brooklyn Park, MN
    743
    Mine does 50 top speed on 3s, NEVER gets even warm, could run all day 50.
    "Monster Power" - Mamba Monster Slash!
    Mamba Monster 2WD LCG Slash - Spartan
    637
    What is your gearing?
    My problem is I have only like 25 meters (max) for run my slash, so i cant get the top speed.
    Same here: no heating problems
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    I was looking my slash and I noticed something. The gearing is 14/62, not 14/68, sorry for the problem.
    Theoretical top speed:
    14/62: top speed: 30~ Mph*
    14/58: top speed: 31~ Mph*
    17/58: top speed: 38~ Mph*
    20/58: top speed: 45~ Mph*
    *Wind resistance and drivetrain drag plays a large role in the reduction of the theoretical top speed.
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    castalia ohio
    4,795
    why is your guys hearing so much different then mine? that 14/62 is a gear ratio of 4.43:1, i was running the stock 86t spur with a 20t spur and only at a 4.3:1 gearing.
    is there a benefit to smaller diameter gears? just less rotational mass? or is it just the cc products?
    Drag It!
    637
    I am using 32p gears because have bigger teeth (more strong) and I have 2 t-maxx spur gears , so is more easy get the parts except the pinion gear because the mamba monster motor have a 5mm shaft and the velineon have a smaller one.
    The spur and pinion gears are from traxxas.
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    300
    try a 21/50 gearing
    Emaxx 5s 2150kv 19/65
    slash 3s 3700kv 23/90
    637
    Quote Originally Posted by momort View Post
    try a 21/50 gearing
    ok thanks for the suggestion
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Brooklyn Park, MN
    743
    Currently, I am using a traxxas 54t spur and a robinson 18t pinion. I can run 50 all day long and it doesn't hardly get warm.
    21/50 might be too high. But try it and see I suppose.
    And I already said that first thing before, lol. ALSO: use slash 4x4 rear shafts...
    637
    Ok, i am going to try 54/18 and 50/21 but is going to be very fast.
    About the axles:Yep i am going to buy the 4x4 axles, but i saw this axles, What you think? are more expensive than the slash 4x4 axles but are cheaper than the mip axles
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    South of St Louis
    4,988
    Hey kitteh, are you also using the same motor?
    637
    Yes, He is using the same combo.
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    Unhappy Little update: The winter (rainy season) is here.
    So I searched in youtube how waterproof the ESC and I waterproof my ESC.
    First I get something similar of electric tape, but here doesn't exist that so I bought a special silicone and I worked with that:
    Those pictures are a bit old, I think I done the work a bit better and it looks like a cake and sorry for don't take a picture from the heatsink, I forget take pics.
    Now I have a question:
    How I waterproof the Motor? I need sealed bearings?
    Thanks for reading
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    Lightbulb Update
    I was looking on "buy traxxas" things and I found this thing. Is a jumper, and is for make a ESC with 2 connectors (like the mamba monster) and convert to 1 connector.
    I was searching and I didnt found a jumper with the traxxas connector, so I made one (I know, It looks awful ) :
    Now is a bit better...
    Was easy to made:
    You need:
    1- Traxxas female connector
    2- 12 AWG wire(I use 10 AWG wire)
    3- Time....
    Thanks for reading
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    637
    Update
    Today I bought bullets connectors and I made some wire extensions for my motor (I need shrink tube ):
    And I made a homemade ESC mounting plate.
    Also I bought a pair of traxxas slash 4x4 driveshafts
    And that's it... Thanks for reading
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Brooklyn Park, MN
    743
    That wire looks like scosche subwoofer wire. Looks pretty good. How do you like it so far?
    Samsung Epic - Tapatalk 2
    South of St Louis
    4,988
    Are you still using nimh batteries? You need to go lipo my friend. And btw, my initials are DRB. Lol
    Brooklyn Park, MN
    743
    Oh yeah, your missing out!
    637
    Yep... Is a subwoofer wire (8awg). I really like the color and is semi-transparent for see the the electricity passing (lol i am joking)...
    I love the mamba monster combo. You are correct, is like the VXL when you know the throttle control...
    Yep still using NiMH until the batteries die and I will change the batteries to lipo and a new charger...
    But the mamba still have the enough power with NiMH...
    Yeah i know...
    Maybe i am going to buy the battery in December but i need you help for choose a combo:
    2x 2s lipos batteries (for use my mamba and my vxl system)
    Or
    1x 4s (for my mamba only)
    Or
    1x 3s battery (with my "special" connector when is using my mamba and for my vxl system)
    I want the 3s battery for use my vxl system too, but i think is just way too low for the mamba...
    Or
    Use the 2x 2s lipo battery for use my vxl and my mamba monster but i think is very expensive ( I think this combo is the best...)
    For the charger i am going to buy the traxxas ez peak 6 amps charger.
    And now i have a questions: what happen if i use my velineon 3500 motor with my mamba esc... Using just 3s lipo battery MAX. If nothing happen i am going to buy some bullets connectors...
    Thanks for reading
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    South of St Louis
    4,988
    No problems with this setup, just try not to smile too much. I used a MMP/velineon 3500 for a long time with good results, on 2s and 3s. Your alu motor plate should cool things off nicely while you run it.
    Brooklyn Park, MN
    743
    Get 2 3s batteries! Less weight is good. Next step is lcg like I am trying to put together.
    637
    Yeah DBG are my initials
    Ok... And what happen if i run 4s? Overheating? I read somewhere when i run 4s in a 3000kv motor or more, the rotor is going to explode like a granade? Is true?
    Well i said 2x 2s (for run my slash in a race) but is a nice idea too
    Btw... Very nice build.
    Just for know... What is your gearing? Right now i am running 20/58 but is very slow (but with nice torque)
    I have 14, 17 and 20 pinions and 58 and 62 spur gears.
    Maybe i am going to get 54 or 50 spur
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Brooklyn Park, MN
    743
    The mamba monster is made for 6 cell lipo.
    My gearing is 17/54 and I use a 3s lipo. Stays cool with the fan on and tops out at 50.
    Knoxville, TN
    592
    Well the vxl 3500 is made for 3s max so I would say first some serious heat followed by smoke and if your lucky enough to make it past that the rotor will let go but sadly the case on this motor is pretty thick so I think it will stay contained. LOL
    Brooklyn Park, MN
    743
    On my second 3s run on the VXL, my rotor broke into like 3 pieces... =P
    Knoxville, TN
    592
    How did this happen I run 3s on mine almost every day. Only had to change the bearings once. But I think it has broke almost everything else in the drive line.
    South of St Louis
    4,988
    Yea I break driveshafts with my 3s slash too. But that's about the only problem I've had with it
    637
    Yep, I know is made for 6s, but I dont want try it because if the vxl 3500 in 3s break the driveshafts, I cant imagine with a mamba monster . I think is a bit better with 4s
    so is safe...
    Ok... well... I think is the same history with 2x in series Nimh 8.4v, right?
    Overheat?
    That's why i dont want to try 6s
    Both at the same time?
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Brooklyn Park, MN
    743
    I was looking back at your posts, you can use a needle nose pliers and push the pin out through the esc connector on both sides and then just have one connector, much cleaner setup.
    and yes, the velineon probably did overheat, running up and down the street at full blast, the velineon just wasn't going to have it.
    I've tried 6s a few times, it does not handle well with that kind of weight, would need a full suspension tuning.
    You cant break both shafts at the same time because when you break one, the differential just unloads onto that wheel.
    637
    Ok thanks for the suggestion . Did you have a pic of you special conector?
    Ok, I am not going to try the 3500 with 4s
    With 6s I think is a bit fast for bashing and now I am going to race with it, so the rules say i only i can use 2s, so I am going to buy 2x 2s for mamba monster and use one 2s for the VXL
    In the driveshafts... I read in plural so I was a bit confused...
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
    Brooklyn Park, MN
    743
    There is no special connector, that's the point. Just take a pliers and push the esc bar/pins out of the connector.
    South of St Louis
    4,988
    Is the connector to run a MMM with one battery that has dual battery plugs?
    South of St Louis
    4,988
    I tried the steel output yikes with the 4x4 shafts and it won't work, the shafts are much to large to for on the steel outies.
    Brooklyn Park, MN
    743
    The jumper is for one battery, yes.
    I made that mistake when I tried to switch to the new axles, jsut bought the center sliding bit and it was too loose. fell right out.
