Thread: Tires and rims
    deep in the myan jungle..
    330
    Tires and rims
    I run on grass and and gravel/loose dirt, so my question is what tires should i use for this runningg combo i know i wan to use desperado rims and i have no clue what 1/2 offset means so let me know what tires you guys think are the best combo for these rims and what offset means, thanks
    8 traxxas models and counting....
    kansas
    7,821
    off set the easyest way to look at it, the more the off set the wider your truck stance will be.
    The Summit Geodes have around 3/4" off set, so my Revo stance is now 17" wide....
    tires......17 pages to look thru..
    I like the Badlands, lite tires, good bit, & not to hard on drive shafts & other parts......
    http://traxxas.com/forums/showthread...-with-pictures
    Oct 2010
    NJ
    777
    In the RC world, any offset means the wheel sticks out further. So a wheel with 1/2" offset sticks out 1/2" further than a wheel with zero offset. In real 1:1 cars, this is referred to as negative offset.
    In the diagram below, the negative offset wheel sticks out further from the car body. This is like having 1/2" or more offset in RC language. If you notice, zero means the hub mounts directly in the center line of the wheel.
    And I'd go for Badlands to fit on Desperado/Traxxas wheels. Or if you can find them the old Proline 40 Series Mulchers.
    Jul 2013
    Québec, Canada
    111
    Very instructive.
    Aug 2013
    Ont, Canada
    66
    I just put a set of Badlands on mine with the Desperado 1/2" offset rim. The truck is now a little wider which makes for better handling. They really do hook up well on the dirt. There appearance is a little different because they are narrower than most monster truck tires, but that's why they hook up so well. Same idea as a good snow tire. Just don't run them hard on pavement.
