    Northern Illinois
    151
    will hitec hs-5086wp servo fit without any modifications
    Just curious if this servo is a direct replacement that doesn't require modifications
    Stampede 4x4 vxl
    Traxxas 1/10 Rally
    Alma, MI
    12,287
    Northern Illinois
    151
    So from what i read the 390DMH is a viable option, that is a direct replacement that doesnt require any modifications. Waterproofing on this model is not a concern for me
    Stampede 4x4 vxl
    Traxxas 1/10 Rally
    Alma, MI
    12,287
    390 Set Up
    All stock hardware is used.
    NONE of the hardware included is needed!
    There are tab braces that do not allow the servo guard to sit flush.
    IT IS OPTIONAL TO REMOVE THEM.
    I have done this both ways without any adverse reactions.
    Here is a picture of the braces:
    (thanks goes to danielhr77 for the picture)
    The tab braces create a small gap between the chassis and the servo guard.
    Here is how it plugs in:
    You will also need to reverse the servo direction.
    These are the steps to follow to do so for LINK:
    Hold MENU for 3 seconds
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    Northern Illinois
    151
    Thanks a ton for info
    Stampede 4x4 vxl
    Traxxas 1/10 Rally
