Results 1 to 30 of 30
    May 2009
    Edmonton, Alberta
    3,604
    Ken Block v2.0 Rebuild thread.
    Decided to do something a bit different with my Ken Block on this build. With the recent release of the Proline Camaro '11 for these cars I knew what shell I was starting with.
    Then it was just a matter of what I wanted to do.
    I bought 2 shells.
    One will be determined later on as far as how it is going to be painted. My painter gets artistic freedom on that one lol.
    The 2nd one, will get pained up 5-0 style. Complete with working Light-bar.
    It is going to be the chassis Black and White cop car look, white hood, roof and doors. Black everywhere else.
    Something along these lines, but the hood or at least the cowl section of the hood will be white as well.
    And aside from the stuff I cant change the color on just yet, or haven't received the parts to do so, I mean everywhere. Although I may leave the Green links, just because they actually look really cool against a solid black chassis.
    Changed over to RPM axle carriers as well.
    Rear differential is locked with the traxxas lockers.
    Did the tear down and clean up today, after getting everything dyed yesterday. Changed out a lot of parts for new, left me with a nice bag of spares (which knowing me will undoubtedly end up as a MERV or something).
    Light-bar is mocked up, I still need to decide where the switches are going to go, as well as the battery.
    I also need to find a nice and small rocker switch to turn them on and off completely, which is the only thing I was really surprised about with this kit, there is no power button.
    What I like about the kit is once everything is mounted it is independent of the chassis and 100% attached to the body, so no accidental wire breaks when popping the body off. (happened already with the roof light bar on my 1:10 Summit)
    Light-bar in action.
    More to come.
    Southern Va
    88
    Like this build so far..Suscribed!!
    Dec 2006
    4,386
    Nice! I have a similar idea using the same body but a as Pace Car...
    May 2009
    Edmonton, Alberta
    3,604
    Little update. no camaro shell yet. my painter is in the process of moving so i may or may not get the shell right away. but thats ok, he doesnt charge me for the paint jobs so im not gonna rush him.
    saw someone else do it so as soon as i was able to get my hands on a new kb shell i decided to pull the decals from this one that has seen better days. i love the clean look.
    i also added in a plug to power the light bar instead of adding a battery which would surely work loose and come flying out. Did this while changing over to a spektrum rx to run with my dx3c.
    can you find it?
    May 2009
    Edmonton, Alberta
    3,604
    odd, posted a 2nd picture in the above post, doesn't show up.
    errm now it does. i confuzzed.
    heres some others.
    May 2009
    Edmonton, Alberta
    3,604
    new tires are mounted. omg wow these were tough to get on there.
    given how tight they are do these need the full glue bead as well?
    I don't know how I'm going to get 4 dots on each side let alone a full bead. lol
    May 2009
    Edmonton, Alberta
    3,604
    i would edit that if i could, waited too long. sorry about the non traxxas goodies in the photo.
    Those are the drift tires im putting on the 5-oh Camaro.
    May 2009
    Edmonton, Alberta
    3,604
    Body is back finally. Not the Classic black and white i was hoping for, but i don't pay for his work, i just replace materials used.
    I have a 2nd body i can get a Black and White done on if i really want it.
    I currently have the lights set up so that i can either run off the ESC or direct of a 9v.
    Colorado Springs, CO.
    2,011
    yup - thats really sweet! Thanks for the build thread!
    May 2009
    Edmonton, Alberta
    3,604
    Decided to change this up a bit, placed an order tonight from LiquidRC for some RED body HR shocks. (love them on my MERV) gonna try them on here as well. I think im going to remove the Locked rear diff as well. This setup just isnt "proper" stable for drifting. I think going rally style is better for it. Even on the bare concrete in the basement it just doesn't want to drift properly.
    Also ordered some RED dress up parts (shock mounts/motor mount) from the LHS.
    Pics of progress to come
    May 2009
    Edmonton, Alberta
    3,604
    Here is my starting point. RPM carriers, Traxxas motor fins Hitec 85mg servo. Stock otherwise
    Tires/wheels are HPI something or others, totally messed up the glue on them (used thin for some reason, ran everywhere)
    w/camaroRS
    w/stripped KB shell
    *** I'm still on the lookout for a NIP KB shell if anyone catches wind of one.
    May 2009
    Edmonton, Alberta
    3,604
    Got some of my parts today and installed them. this GH "Red" stuff sure doesn't look very RED to me.
    Also got a differential repacked to swap in once i decide to do it. Then i will take the lockers out of that one and repack and install up front as it was a new diff all together so I'll just have to drop the inner parts in and fill.
    May 2009
    Edmonton, Alberta
    3,604
    HR shocks, used green revo springs for the red factor but i have to change to the whites from the rally obviously, it stays jacked up.
    May 2009
    Edmonton, Alberta
    3,604
    Just a pic, nothing new as of yet. Playing around with turning my workbench into an occasional photobooth.
    SE Texas
    1,178
    how did you get the centers on the KB wheels chrome?
    BTW...too bad you aren't closer...one of the shops here has a NIB KB body on the shelf.
    "Dude,I almost had you"
    R.I.P Paul Walker
    May 2009
    Edmonton, Alberta
    3,604
    They are stock traxxas rims. forget the part #. Picked them up premounted like that from Amain Hobbies.
    Not sure if they were stock trim on any of the 1/16 cars or not.
    Got my Center drive shafts installed today.
    Hoping they hold up fine, have to be better than the stock center shafts. I have lost count how many ears on the yokes i have blown on my 1/16 scale rigs through the last couple years.
    11
    Very Nice Job on the Camaro Body- This is mine that I painted recently, to scared to run it lol.
    Whole album of process here.
    May 2009
    Edmonton, Alberta
    3,604
    Dang! thats a sick looking body.
    Speaking of bodies i finally got word today from ly LHS that they have been advised the KB prepainted/decalled body is discontinued. Dont know why that took so long lol.
    May 2009
    Edmonton, Alberta
    3,604
    Question for anyone who has their KB/Rally set up for drifting, what did you gear it at?
    Mine right now is stock KB gear ratio 28/45, but it steps out way too easy and will snap around very quickly.
    Rear diff is locked.
    Thinking of stepping up to 55t on the spur but should i take some pinion out of it as well?
    11
    I have used my KB for drifting and mainly drifting. I have put form tires on it and ran it around a track but only once. I currently use the optional pin gear that came with it, cant remember the count but I can find it if you need it. I have not locked my rear diff as i didn't feel the need. I also make my own tires out of ABS pipe so its much easier to slide around. I also have the car slammed to the ground and am using 75wt shock oil in all four shocks. I also use different springs on the front and rear. This is how I have mine setup and what I like. This may not work for you but just play around with things and see what you like. The best advice I can give is to make one change at a time and see what you think. I remember reading that someone said these cars were no good for drifting but I think they are wrong. Its not the car so much the driver. so play with different things and find what you like, that is what I did.
    May 2009
    Edmonton, Alberta
    3,604
    Got my 2nd Camaro body for this today.
    Oh my it looks amazing
    Send via most likely stolen wifi...
    May 2009
    Edmonton, Alberta
    3,604
    Sneaky peeky.
    May 2009
    Edmonton, Alberta
    3,604
    Loving this look.
    Already warned my painter that I might look for a twin in my new XO-1
    Norwich, CT
    36
    Nice! I love seeing the camaro bodies becoming more popular
    May 2009
    Edmonton, Alberta
    3,604
    Oh yeah, they are a fantastic body for the 1/16 platform.
    Middle of the Pacific Ocean
    171
    Nice thread. Just an FYI. If you ever try drift tires again, you boil them before putting them on. Makes life easier. Also glue is not needed. Keep up the good work.
    Port Alice, BC, Canada
    1,299
    Check the MP
    May 2009
    Edmonton, Alberta
    3,604
    Hahaha with all due respect. I dont want one that bad.
    Sent from my phone to you. #KCCO
    1,299
    Didn't think so lol. Someone will though. Nice build btw��
    May 2009
    Edmonton, Alberta
    3,604
    Thanks and GLWTS. Might find a Ken Block collector out there
