    35
    controlling a rc4wd bulldog winch with TQi 4th channel
    Hello:
    Some body have experience doing this ?
    best regards
    Alma, MI
    12,280
    Channels 4 and 5 are only half channels.
    Channel 3 is the only channel that can control a winch as it is the only one (besides steering and throttle) that has a forward/neutral/reverse.
    35
    Hello:
    I was reading the web and several forums, then May I exchange the cables from channel 3 switch to channel 4 switch to use 3 position switch on top to control 3rd channel with neutral (or off) in the center position ? there exist a how-to ?
    best regards
    Alma, MI
    12,280
    If you take the wires off of the 3 position switch, you will loose both channel 4 and 5 and you can only gain one of these channels back by adding them to the thumb switch.
    Read this thread:
    http://traxxas.com/forums/showthread...ter-off-switch
    It may help you.
    35
    hello:
    I do it, exchange the cables and re soldering in the board and now 3 position switch (the stick on top) works on channel 3 and has on-off-on and the side switch (red one) works on channel 4 and is on/off .... the channel 5 was lost, only works to supply power for the fan ....
    soon I will put photos and some explanation
    regards
    35
    hello:
    this are the pictures before and after the mod. ....
    Before - original:
    After mod:
    regards
