Results 1 to 22 of 22
    Grafenwoehr Germany
    1,304
    Will these carbs work
    Will ether one of these be a better replacement for the traxxas carb on a 3.3 I got them both off eBay for 6 bucks.
    2carbs
    1. OS 20E came off a NOS rg.21 never ran
    2. RB nova mega, novarossi carb. Came from a nova mega JP black buggy motor which had about 8 tanks before we were sponsored and switch to OS.
    2,215
    If it came off the same size engine then I on't see why not. You'll probably have to screw around with the carb a lot.
    Whats wrong with the 3.3 carb?
    Grafenwoehr Germany
    1,304
    I have been reading a lot about it being to small for that size of a motor
    Wich is why people use the losi 3.4 carb
    2,215
    Quote Originally Posted by Emaxx1991 View Post
    Okay that sounds better. It might be easier to tune but I don't know.
    michigan
    368
    really?? a losi 3.4 carb??
    4,361
    Ya, the TRX carb that comes stock on the 3.3 was designed for the 2.5, so they changed nothing and put a small carb on a bigger engine, but the losi 3.4 carb was designed for the 3.4 engine, so putting it on a TRX engine will give you more fuel flow and more air flow, = more power. Just my .2 cents!
    michigan
    368
    where can I get one??I looked on ebay but couldnt find just a 3.4 carb.I would be willing to try it
    michigan
    368
    ahh ha I found one on aim hobbies 39.00
    Aug 2007
    177
    They work great, they are a 7mm carb. RB523tm carb are good if you can find one and they are 8mm. I just turn what ever carb I have down to fit.
    Master Modifier
    35 years breaking records
    Grafenwoehr Germany
    1,304
    I turned both carbs today but they wont work in my revo there to big and hit the spur
    Grafenwoehr Germany
    1,304
    Ok so here are the throat measurements of each of the carb
    STOCK TRAXXAS 3.3 carb 6mm
    OS carb not sure model 7mm
    And the carb I want to use
    RB NOVE 8.8mm
    Aug 2007
    177
    Show a pic if you can where it is hitting. I had to grid the outside of the carb body also depending what car it's going in
    Master Modifier
    Grafenwoehr Germany
    1,304
    I got it to clear the flywheel by grinding a little on it and I think I can cut a little off my air filter to clear the spur but the slide is a lot longer then the stock carb so I think this would fix it http://www.teknorc.com/shop/tkr1011-...-revo-2-5-3-3/
    Grafenwoehr Germany
    1,304
    Can anyone confirm this or do I need to buy throttle mount
    Oct 2005
    18,541
    Just remember, most metal carbs have an insulative sleeve to thermally de-couple the carb from the engine's heat. One of the reasons why Traxxas uses a composite carb.....
    Robin Williams
    He will be greatly missed...
    Aug 2007
    177
    Doesn't make much difference if your running on road. Helps a little in off road.
    Master Modifier
    Grafenwoehr Germany
    1,304
    I have the insert it's a 7.5mm
    Grafenwoehr Germany
    1,304
    I don't think that carb is going to work though there too tall and the slides are long
    Unique Racing Engines
    74
    Just got done putting a force .28 in my 3.3...... yes it took a while, you cant just turn down the carb or it will crack what little metal is left when you tighten it down on engine. You must take off the metal portion that slides into engine and then a little of the composite underneath and then take an old stock carb and remove the metal part from body of carb and bore it out to fit what is on the 28 carb, epoxy it to it and your done. All i can say is wow, it definitely woke the 3.3 up!!! Idles tons better, off idle is better, and top end is amazing!!! Tuning is no comparison! Very easy to get the sweet spot. i do have a flow bench and need to make some adapters to flow these carbs and try to find more flow......
    Aug 2007
    177
    I wish I could get my hands on a bunch of those RB523 carbs.
    Master Modifier
    74
    Quote Originally Posted by Rick B View Post
    I hear you there sir. I have found some old rc's with them in cheaper than what the carb is worth. I like the force. 28, composite with aluminum important parts, and can be found for around $20. Thinking of trying to turn down an adapter "plug" to work in the 3.3. Would make it a ton easier to get to fit.
    Aug 2007
    177
    Already working on that.
    Master Modifier
