Results 1 to 9 of 9
    Arkansas
    335
    Esc question, help please.
    Hi, I just used the castle link software. I plugged everything back in. I started it up. The fan spins, no lipo cell count beeps.. radio and receiver are good. I have steering, no throttle.
    Everything seems like it is plugged in correctly.
    Any ideas?
    ERBE, MERV BB
    3,259
    Have you tried to update the castle software...my mate had a similar issue a while back and that was the problem.
    Rock n Rolla !
    kansas
    7,894
    any time you make any adjustment to the ESC you need to reprogram throttle, brake, & neutral end points.
    that should get you going idb, even if you change from the 50/50 & 70/30 you need to reprogram..
    last thing make sure you pluged the ESC wire in with the darkest wire out on the Rx........
    Arkansas
    335
    87 can you explain the darkest wire out thing... I took it as a negative so I aligned it with the servo plugs.
    I believe I have to recalibrate because of the new radio transmitter. I have followed the castle manual, but it doesn't work. Just a lot of beeps.
    ERBE, MERV BB
    kansas
    7,894
    the brown or what ever is the darkest of the three wires goes to the outer edge of the Rx, need a pic I think I have one,
    j.a.m.
    edit best I have
    http://traxxas.com/forums/showthread...=1#post4922981
    programing the ESC
    aod's link
    Refer to this to setup the Mamba Monster ( MMM ) esc for maximum performance:
    CASTLE LINK GUIDE
    Arkansas
    335
    Yeah I understand. I need help calibrating my new radio to the esc..
    ERBE, MERV BB
    kansas
    7,894
    Speed Control Programming Instructions
    The Castle Creations Mamba Max speed control should not need
    reprogramming with normal use. However, if you install a different
    radio system in your model, or change the transmitter’s throttle-neutral
    setting from 50/50 to 70/30, you will need to reprogram the speed
    control. Follow these instructions to reprogram the speed control:
    1. Install the batteries of your choice in the battery compartments and
    plug the batteries into the speed control.
    2. Switch on your transmitter.
    3. Hold full throttle while you switch on the Mamba Monster controller.
    After a few seconds, you will hear multiple tones and the
    RED LED will light.
    4. Hold full brake. After a few seconds, you will hear multiple tones
    and the YELLOW LED will light.
    5. Release the trigger to the neutral position. After a few seconds,
    you will hear multiple tones and ALL THE LEDs will light.
    Arkansas
    335
    Ok somehow I got it to work! Thanks!!!
    ERBE, MERV BB
    jacksonville fl
    247
    We're all the lights flashing on the esc? If yes was prolly that you didn't have the esc plug in the rec port well enuff .
    ERBE, BRUSHLESS SUMMIT, EMBE
