Results 1 to 12 of 12
Thread: This a problem?
    79
    This a problem?
    When I opened my front diff, it had some oil in it, but it definitely was NOT full to the brim. Should I refill it to completely full? Or is it supposed to be like that stock? I never saw any leaks after any runs, so I dont know where it all went, or if it just dissipated. what is a good oil for mainly bashing with some speed runs and maybe track-time once I get into it?
    Riverton Utah, The Most Windy City in Utah!
    2,095
    If you run on pavment, like I do, try putting in a really thin diff oil. I use grease, not oil. It helps on pavment, to not flip it and it gives you a really tight turing circle!
    79
    I am more off than on road for sure, so not so sure about that. stock is 30k front 50k rear correct? going higher like 100k will do what?
    kansas
    6,295
    120k F&R fll it full, & get all the air bubbles out......
    You are talking the carrier not the diff housing?
    http://traxxas.com/forums/showthread...=1#post4899891
    SumRevo now has a locked rear diff, but it is Brushed truck
    Arkansas
    389
    GN what brand of diff oil do you like?
    79
    Nope, pic # 3 on your link, not full like that, actually, nowhere close. I also didnt put anything like that white stuff on in pic #4
    79
    also, does heavier weight like 120k protect the diffs a little more?
    Western Kentucky
    782
    The thicker the diff oil the more positive traction affect you get...
    ERBE,Losi 8ight,Slash 4X4
    2,883
    In my experience if you still wanting to do speed runs or ride on tar the thicker oil will be no good for you. Are you running 4 or 6s?
    I run 50k front and 30k rear as an all round setting...this works well for me.
    When I open my diff cup, even after a few runs the cup looks a lot less full that what I packed it with.
    I'm a Rock n Rolla !
    kansas
    6,295
    Quote Originally Posted by BlackSheep800 View Post
    OFNA
    Quote Originally Posted by beastaudio View Post
    I fill the carrier about half full & then put the gears in, top it off, then let all the bubbles float up. When you reassemble the carrier you should have diff fluid comeing out the last screws hole. You are defeat the purpose if you don't fill it full & get the bubbles out.
    Nope
    Why? Revo has so much power, it can make it diff with the blip of the throttle, even with 120K...
    I like a little diff, to help with tighter turns, but hear again blip the throttle & it will spin right around.
    If all wheels are not pull the truck forward, & two wheels diff'n you are going no where fast....
    JMHO.. but to each his own...driving style, location etc..etc all factor in.....
    2,883
    I tried it about a month back when I rebuilt my diffs. I found for me, and my driving style the 120K diff lube horrible. It made my truck hard to handle and under accelaration on the dirt the truck was all over the place. It was even worse on the tar...when I accelarated the truck started bouncing all over the place. I absolutely destroyed the tread on my rear tyres on the tar with 120K diff lube. Maybe I didn't give it enough time to get use to it and adjust my driving style to suit.
    After a couple runs and front and rear stripped diff I went back to what I had been using for a while. 50K front and 30K rear...I think it had a lot to do with the way I use my truck as I like the power of 6s and to go fast all the time ...thou I am changing and have recently bought myself a set of 4s. I am tired of destroying diffs . Haven't warmed up to the idea of the losi conversion yet
    79
    CM, we share the same thoughts, I just scooped some matching 2s batts and im going to start using 5s and if I still have issues I dont know what ill do. The losi diff seems like the ticket, but seems a little outa my league, so im going to hold that off as long as I can...
