+ Reply to Thread
Results 1 to 10 of 10
Thread: Offset question
    May 2009
    Edmonton, Alberta
    3,099
    Offset question
    If i am running some HPI vintage wheels can i get away with +3mm offset? Or +6mm?
    Or should i run 0 offset
    They have exactly the wheel I'm after for my new Proline Camaro RS cop car.
    Also anyone have experience running a stagger? 26mm front and 31mm rear?
    Does this upset the handling on the RC scale or not?
    (RAH)² (AH)³ + [ROMA (1+MA)] + (GA)² + (OOH)(LA)²
    Rotterdam, Netherlands
    6,229
    Wider rear tires will probably increase oversteer.
    Nobody is born with experience.
    St. Louis, MI
    8,145
    I have not had any issues running 31mm all around...
    I had thought of going with 26/31, but since it is 4wd and could use all the traction it can get I put 31 at each corner.
    Before I enlarged the wheel opening
    After I enlarged the wheel opening
    May 2009
    Edmonton, Alberta
    3,099
    that doesn't look too bad at all with 31's all round. Maybe i'll wait on tires until i actually have the Camaro here and then see what i have to work with in the fenders.
    Bay Area, CA
    438
    3~4mm offset is stock fitment so won't require any body mods.
    On the Rally body at least, 5mm is problematic unless you run a lot of camber:
    The prototype project.
    Jun 2003
    We-Go, Chicago, IL
    2,628
    3MM OFFSET 26MM should work fine, but you can also use the 31mm wide in the back too, just might have to narrow the rear via threading in the pillow balls and shortening the rear tie rods if you have the adjustable ones.
    Aw, Biscuits!
    May 2009
    Edmonton, Alberta
    3,099
    Good to know, i decided to wait until the body is here. its tough to tell just how the fenders are when looking at the pics of an uncut shell.
    May 2009
    Edmonton, Alberta
    3,099
    Looks like i should be able to run +3 with no issues at all.
    Aug 2009
    27
    where did you get that light bar?
    The Mitten
    1,628
    Quote Originally Posted by bonedog65 View Post
    Here:
    LED Police light-bar
    Everything overpowered...
