Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 80 of 143
Thread: My XO-1 mods
  1. #41
    Garden Grove CA
    140
    The front air duct will be going to the esc to help it stay cool at high speed. Been reading everywhere on how they heat up and die on people so that's the solution. Still waiting on the light weight flexible hose from china though for that mod to be complete.
    The front of the car I had notice that the factory canard is very flexible, so I don't think it's reliable for 100+ runs.
    This is what I did for more rear DF. Just add a hard rubber o-ring to the back of the wing mounting screw to lift it up in the back. Try one first to see if it's enough DF for you. Add two and you might scrape the rear diffuser so stiffen springs in the rear.
    Also make a mounting plate for the rear body mount and wing. The body is very soft so this helps transfer the DF to the rear wheels. Do the same for the front, it's much easier.
    With all the air going inside the car it's actually trapped in the rear and forces it downward right where the diffuser is so it'll create a bit of a lift and act like a parachute. I added vents on top rather than right next to diffuser.
    Also slvr bullet I think this car is very capable of reaching very high speed if you have time, money and patience. Most of my mods here will help you getting more df. If you have any questions or need help lmk.
  2. #42
    30
    thanks for the pics will get my project started. Time and money I have its patience is my problem
    never can own to many rc cars
    to many to list
  3. #43
    Sep 2008
    263
    Nice job! Thanks for sharing it
    Q: how do you cut the lexan, it looks quite clean!
    Did you cut cut other vents, then the one in the "license plate area"?
    Thanks!
  4. #44
    Garden Grove CA
    140
    np. I use a hot razor that I got from radio shack ($20) to cut out the vents, then borrowed my wife's nail filer to smooth out the lines. Just don't let the females know or you're in big trouble .
  5. #45
    Glendale, AZ
    253
    Nice, may have to steal your idea later. Looks awesome!
  6. #46
    30
    Quote Originally Posted by FartOfDoom View Post
    tell me about it my wife isa nail tech and if I touched her stuff she would have a heart attack
    to many to list
  7. #47
    Garden Grove CA
    140
    LOL yea do not touch their stuff
    here's how to remove play in the front steering bellcrank. dont worry about having it too tight, it'll loosen up after a few run
  8. #48
    Lexington, SC
    1,345
    I'm thinking this car doesn't really need the rear wing. I'm not using mine at the moment. We'll see what happens.
    Creator of the world's best 1/8 scale 2wd Slash!
  9. #49
    30
    let us know. i think that might be a mistake
    to many to list
  10. #50
    Sep 2008
    263
    I am sorry, I dont understand what you have done there!
    Could you explain it a bit more, pls?
    THX!
  11. #51
    Lexington, SC
    1,345
    Looks like he wrapped it with Teflon tape.
  12. #52
    Lexington, SC
    1,345
    Quote Originally Posted by slvr bullet View Post
    My 95mph rustler didn't need one but youmay be right. Only time will tell.
  13. #53
    Garden Grove CA
    140
    Yep it's thread sealer/teflon tape wrapped around the shoulder screw for the steering system. very simple mod to remove unwanted play. working on anther mod right now, will post up pictures in a bit.
  14. #54
    30
    yeah ponie keep us informed on that one i would love not having the wing on mine also just was scared to start messing around with the design of things. like everybody knows they get airborne very easy
    to many to list
  15. #55
    Garden Grove CA
    140
    Here's another mod to help remove more slop in the front. What I did was ordered 2 #30 (.1285) drill bits and cut them down to size. Put it on a drill press then use a dremel to cut slots for e-clips to go through on each end. Now it's close to zero slop up front. You guys don't have to drill anything here. It's the exact size of the hole
    Here's how it looks like installed
    This mod is simple and very useful. Installed 5 o-rings size 6x8x1 in the hub retainer bolt that goes in the hex hub. What it does is to help smooth out vibration between the axle and hex hub
  16. #56
    665
    mods look great , only thing I would do it make doubles of everything because you will need them regardless if your planning togo over 50mph
  17. #57
    Lexington, SC
    1,345
    Yeah I'll let y'all know. I gotta get the shelf queen out there and go all out. It's time.
  18. #58
    Charleston SC
    349
    Quote Originally Posted by ponie1992 View Post
    The down force helps keep traction on the rear tires. I ran a few times under 70mph when my wing got ripped off and could tell that the car was a lot more skiddish without it.
    E Revo brushless, XO-1, Nitro 4 tec 3.3, HPI RS4
  19. #59
    Dec 2006
    3,980
    Nice! Keep them coming!
  20. #60
    Garden Grove CA
    140
    Will do sir. Been too busy to ask my friend at the airbase for some run time. I'm currently working on getting actual foam tires made for this car. Calling a few of my suppliers out of county to see if it's possible... Fingers cross 2" 1/4 wide in rear and 2" in front
  21. #61
    Charleston SC
    349
    Get them 4.35" in diameter too. BSR's come at around 4.10"
  22. #62
    665
    be nice if somone made some treaded belted tires in our size
  23. #63
    North East Texas
    18
    GREAT IDEAS!
    I have not done this yet on my XO1 but over the years I have used brass or aluminum tubing to make crush-sleeves to fit between the inner races of both inner and outer bearings to reduce slop. Time consuming as YOU would know (mill off .0005too much and you start over) but worth the trouble.
    This is a reply to FARTOFDOOM's Outer Hinge pins (drill bits) and hub retainer o-rings. I almost know I clicked on "reply with quote".
    SORRY!
    By the way: Thanks BennyG6 for your replies in the picture and video thread.
  24. #64
    San Jose, Costa Rica
    640
    Any updates?
    Very interested in this project.
    Slash 2wd w/ MMC
    T-Maxx 3.3#4907
    Summit 1/10
  25. #65
    Garden Grove CA
    140
    Well guys(comma) I(apostrophe)ve officially started on the foam project and this thing is going to be EXPENSIVE(period) But it(apostrophe)s well worth it(exclamation mark exclamation mark exclamation mark) I(apostrophe)ll update you guys when everything is done (smiley face) If you guys have any questions or need help with any of the mods feel free to give me a pm(period)
  26. #66
    North East Texas
    18
    Can't wait to see the results. I just about fell out of my chair laughing when I looked at this. I think they were a bit too harsh and that's all I am going to say about that.
  27. #67
    Garden Grove CA
    140
    LOL yea I thought it was kinda funny how the asterisk (the little star looking thing on the #8 button) could be so offensive when clearly I was telling another member you couldn't use it to cover letters. But yea back to the subject...
    Finally my gyro came in the mail!!! Still waiting on my setup station UPS got delayed till Monday.... Installed pic will be up in a bit, gotta go cook mah steak!!!
  28. #68
    North East Texas
    18
    What kind of setup station are you getting? I thought about calling Hudy to see if there 1/8 scale station would work or if they had any plans to build one specifically for the XO1. I even thought about modifying my current Hudy stuff. I am anxious to see what the "'aftermarket" (in genera)l does to support this car.
  29. #69
    Garden Grove CA
    140
    I got the intergy 1/8 universal setup station(http://www.integy.com/st_prod.html?p...3#.UC9nDfXg9Ow)
    I was thinking about modifying my Hudy to work with this car too but then the intergy isn't that expensive so might as well.
    Dual links front mounted directly to the steering block with gyro installed.
    Good:
    Tighter steering system
    More responsive
    Bad:
    It's a pain to adjust
    Same with the rear.
  30. #70
    Garden Grove CA
    140
    I think I've found a very simple solution to fix the front suspension but I need someone with a new untouched steering system. If you guys don't mind spending a few dollars and have a digital caliper in hand feel free to pm me. This mod wont be as smooth as mine though but it will make your car a lot smoother and easier to drive.
    Also require you taking pictures to post on here so we could share the mods with everyone.
  31. #71
    My home, Squirrelville, Wild West
    631
    If you can afford all of this awesome equipment, you could at least put some cuut screen over the front intake...
    Only 70 MPH? MORE LIPO!!!!
  32. #72
    Garden Grove CA
    140
    Quote Originally Posted by MooseSlash View Post
    Take a closer look again at the body, upper section barely have any mounting space and lower section is completely gone. What do you think @ 100mph that "cuut screen" of yours will do? I'll leave this one to you genius
  33. #73
    Montreal, Canada
    450
    FartofDoom is this the one you use as a spacer for between those 6mm bearings?
    http://www.ebay.ca/itm/Traxxas-2746-...#ht_3766wt_689
  34. #74
    Garden Grove CA
    140
    no sir they're made from a different company, part # KYO96641.
    They come in 10x 3x5x.1, 10x 3x5x.2mm, and 10x 3x5x.3mm
    Kyosho parts are permitted, as are almost every other brand.
    -ksb51rl
  35. #75
    Montreal, Canada
    450
    Big Thanks FartOfDoom! I know that brand, I'm doing the steering mode now, without the washer, I did install those bearings already, working smoothly but I still need those spacers, just in case it might slip.
    On the suspension pins I have the replacement also, I want to ask if what you did to cut it in size, did you grind it or use a bolt cutter?
  36. #76
    Garden Grove CA
    140
    no problem I'm here to help . I used a dremel and a standard cutting disc to cut the shaft down to size. measured the stock shaft with a digital caliper and it's 54.51mm exact
  37. #77
    Garden Grove CA
    140
    Here's a simple mod that's very easy to do if you want more front end down force.
    I drilled a hole through the foam bumper to the high speed canard and put in a screw and washer so that it's a little stiffer for more down force.
    Here's a vid of the result
    Sorry wife was being a pain in the something in the back ground
  38. #78
    Garden Grove CA
    140
    I'm working on a mod tmrw that will reduce the bump steer (thanks to blacky2kgt for pointing this out) and will also help with the overall steering throw/sensitivity for better control (this one is for TheStenchOfSpeed) if you like to drag the beast. BTW nice setup TheStenchOfSpeed
  39. #79
    Norf Cackalacky
    301
    Thanks. I actually made a mod to improve the bumpsteer that made it worse, lol. I thought for sure it would make it better. Working on a new idea right now.
  40. #80
    Charleston SC
    349
    Just curious... how is that gyro working out for you?
